Question about KLH CDR2000 2-Disc CD Recorder
Deck a will not eject
Deck A seems to be stuck. Can hear whirling but does not eject
  • 1,267 Answers
It is a belt that is loose and the motor that is slipping is the noise you hear. Usually if you can get the belt out and measure it subtract 5%
Posted on Dec 25, 2012
    New Friend:
  • 3 Answers
I just hit the top front of it and try to catch it before it goes back in.
Posted on Jun 24, 2013
  • Sam Palermo
    Sam Palermo Jun 24, 2013
    If the belt is loose then hitting the deck on the top will only damage the unit further. Where do you get an idea like this?
Anonymous
SOURCE:
Denon udra-77 hi the cassete deck will not eject or close on pressing the open close button, the rubber band between the wheel is intact, it will activate when manually turning the top wheel, seems to be...
The mechanism maybe out of alignment. Technicians and a service manual is how this gets fixed. The new belts are put in an the mechanism is position to the stop mode for the eject to work.
Feb 09, 2014 | Denon DRR-M30 Dual Cassette Deck
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
I can't eject the cassettes from the deck - both seem to be stuck. How do I fix this problem?
only one way. I did this before. take your fingernails, stick them in the top of the door, and pull. want to use it again, put tape to hold door close.
May 11, 2010 | Sony TC-KA3ES Dual Cassette Deck
Can not eject tape
HI,
It seems that the deck was stuck or some parts have stuck to lower down the deck. You can try to push the eject button while helping the deck by gently opening or lowering it down. Just be careful on doing this to avoid any further damaged on the rotating gear inside.
Hope this helps .
Let me know for any clarification
Nov 29, 2009 | Canon ZR65MC Mini DV Digital Camcorder
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
KLH CDR2000 2-Disc CD Recorder Logo
112 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
