Is there a way to override the tone cartridge replace message? i like to drain every last bit out of each cartridge. i keep a black on hand but it always seems like one of the colors runs out at the worse times (late at night or when i am on a dead line).
any options?
thanks
jim
SOURCE: K550 printer not printing Black
It seems this affliction is reported many times on the internet, new out of the box the black print head is bad.
1st run the cleaning utility on the driver CD.
then.
If it is in warranty call Hp and give them the info.
it is unlikely the print head is clogged or it would print some garbage.
If it is out of warranty. then feel free to take it out and clean and check/reseat the connections to the print head.
The paper handling jams are the next biggest complaint.
SOURCE: LaserJet 3550: override chip on toner cartridge to continue print
Disable Carts is for service tech troubleshooting.
You will have to replace. All prints use all cartriges every time.
SOURCE: HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this. Take it back and get the exact replacment, including the brand.
SOURCE: trying to put back in the color ink cartridge for 6210
The printers are bad about damaging the ribbon cable inside the print cartridge when you replace the ink cartridge. There is a small wire spring that gets pushed through the cable rendering the printer useless. Poor design by HP. How do I know? I did it to mine. It's cheaper to buy a new one then to have it repaired.
SOURCE: HP Photosmart C7280 color ink running out despite not using it?
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the
power cable.
