Question about Vulcan Heating & Cooling
I need a manual for vulcan electric wall furnace 40 mj ng jet 3.0 220-240v ac 90 w kPa Hi-0.95 Lo-0.2. Is it cost effective to run?
SOURCE: Hi there, I have a Vulcan Gas Wall Furnace Heater
Hi
Please see this link to view/download the manual fro your heater---
Vulcan Gas Wall Furnance Heater
Please accept this solution and ask for any assistance.
Thanks
Rylee
Posted on Mar 29, 2009
SOURCE: Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Posted on Oct 08, 2009
SOURCE: Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Posted on Apr 30, 2010
SOURCE: 20 year old Rheem 90 plus 120k btu furnace blower
Check to see if your unit has a heat sequencer. This is usually the problem with most furnaces. If it is bad, it will make the fan blower run all of the time. If you are not a electrican, you may want to get a electricin to look at it.
Posted on Dec 01, 2010
Apr 05, 2015 | Vulcan Heating & Cooling
Mar 02, 2014 | RVs
Apr 14, 2011 | Vulcan Heating & Cooling
Dec 21, 2010 | Heating & Cooling
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Oct 05, 2009 | Heating & Cooling
Mar 29, 2009 | Vulcan Heating & Cooling
Jul 27, 2008 | Heating & Cooling
Jul 23, 2008 | Heating & Cooling
419 people viewed this question
