Insignia NS-LTDVD19-09 LCD TV Logo
Question about Insignia NS-LTDVD19-09 LCD TV
My insignia tv will not turn on
I cannot turn on the tv with my remote control or manual
SD Tech
    Top Expert:
  • Insignia Master
  • 14,553 Answers
If its total dead look for a fuse inside and if bad replace it. If any light comes on but set does not you would at the least need to open the set and inspect the power board for puffy filter caps and for voltages coming in and going out of that board.
Posted on Dec 20, 2012
5 Related Answers
Anonymous
SOURCE: programming my tv & remote
dude i have the same tv and problem that you have i have found 4 codes that work for me. mabey they will work for you, 8820, 0463, 0150, 6131
Posted on Dec 22, 2007
Anonymous
SOURCE: jumbo universal remote
Universal remote codes for Insignia products: http://www.insignia-products.com/skins/Skin_1/Topics/Documents/Insignia%20TV%20Universal%20Remote%20Codes%207-9-07.pdf
Posted on Dec 28, 2007
Anonymous
SOURCE: Insignia TV code for Sony remote RM-V302
press tv, hold setup til tv blnks twice and release setup, type 10463 then power. 5 digit code not 4 like most.
Posted on Jun 19, 2008
Anonymous
SOURCE: Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
Posted on Aug 28, 2009
Anonymous
  • 54 Answers
SOURCE: I am trying to program my Insignia TV remote to my
Insignia TV's are made by Sansui....try one of their codes.
Posted on Sep 27, 2009
2answers
I need to find out where the control panel to turn the tv on and off is located.
Some tv sets don't have any sort of control panel and rely completely on the remote control.
I Have an insignia tv and lost the remote control, I was able to find a similar insignia remote control to the one I lost. How can I program the new insignia control remote I acquired to my insignia tv.
Hello
All Insignia TV remotes are not alike. The frequency of infrared rays out from each remote control will be entirely different to each other according tho the model numbers of the TVs and remote controls. A typical model will have same model number of remotes, and the remote you have got is with the same model of your tVs it must work proper. Otherwise you have to buy a new one for your Insignia TV model. you can bought from the authorised service center for Insignia at your town. If you have no access to authoised service center nearby you, just buy one universal remote control, which has set up codes for Insignia. . Check its manual, that it have setup codes for Insignia. OK.
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
IR Remote Control Remote Control: how do I set up my remote with a brand new insigni...
If you have a universal remote control, programming details are included in the remote manual. If you need to program the Insignia TV remote, details are also in the TV owner's manual. If you need a copy of the manual for your TV, a downloadable version can be found at InsigniaProducts.com by searching for your TV model number and clicking Support.
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Insignia tv remote programming
An owner's manual for your TV can be found at InsigniaProducts.com, just search for your TV's model number and click on the Support tab. It should include complete instructions for programming your remote control.
4helpful
How to turn on TV with insignia digital converter remote
You'll need to program your remote control for your TV. To do this, ensure that your TV brand is one that can be controlled by the remote (a listing is in the owner's manual). Turn on your TV, then press and hold the TV Power button on the remote and press the Channel (CH) ^ or v buttons one or more times until the TV turns off. I hope this helps.
29helpful
2answers
20helpful
4answers
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
