My temp gauge stays on cold, but I have heat coming out of defroster and heater vents. Motor sounds fine(3800). Could this be a sensor or termostat problem?
I replaced sender and dash unit and still no gauge working. Ground sender wire and gauge read hot. Gauge reads about 1/8 way up key off key on goes to bottom cold then turn key to start it goes hot let of key back to bottom turn off key goes yo 1/8 of they way.
Switch ig. on, ground the sender unit wire for about 3 seconds see if the temp. gauge moves, if so change sender unit, if not then it is a faulty gauge reader.
Temperature gauge stays on cold
