Need a code that will allow volume control synch to magnavox lcd tv through the home theater remote. Can only turn tv on/off and get sound through system just can't contol the sound. Have used code 1062
SOURCE: Can't find the code to program RCA RTD207 dvd home theater system
try these codes:
here is another way to program the remote:
thanks
tom
SOURCE: RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
SOURCE: I need a Directv remote
The following website has the process for setting up the code for your TV:
http://2getdtv.com/directv/remote_codes.html
If you experience problems for some reason, contact DirectTV to get some assistance.
Good luck, and hope this helps.
SOURCE: can't find a code to
We would be happy to help with that. Here is a list of someof the codes that we have for RCA home theater systems: 703, 852, 772, 638, 704, and 727.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codesfor your RCA home theater system provided above. Press the pound (#) button, the modelight should flash three times. Checkthat the code works by trying several different functions on the remote to makesure it will properly operate your RCA home theater system. Keep in mind that some codesmay not be compatible with your equipment. If this is the case, please try theother codes listed for that device until you find one that is compatible withyour equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
SOURCE: RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
