Try changing the needle
rethread the machine top and bobbin
try a different bobbin and make sure the bobbin is turned the right
way
also check to make sure the machine is plugged into the outlet
correctly
and also make sure the power cord is plugged into the machine
correctly
and make sure the foot pedal is plugged into the machine correctly
if these suggestions don't help then it's possible that the machine
needs to be serviced
SOURCE: friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
SOURCE: i have a new sewing machine, Euro pro 373stitch help
You can download the manual here.
http://homeappliance.manualsonline.com/manuals/mfg/europro/373.html
Good luck and please rate
SOURCE: help me find a manual for a euro pro 7133 sewing machine
I hope this helps. It took some searching but this is what i found. Good luck!
http://www.sharkclean.com/manual/7133_REV_1204_ENG-SP-FR.pdf
SOURCE: where do I put oil in my euro denim sewing machine
I don't think you oil a sewing machine motor.
Clean out the area under the presser foot. Sometimes built-up lint can cause the motor to strain as stitching extra heavy fabric.
If the problem continues, the machine needs to be serviced by a pro.
