Vivitar ViviCam 3650 Digital Camera Logo
ripon mojumder Posted on Dec 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i inside mamory card into the camera,the donnot pick picture show card is full.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vivitar Master 102,366 Answers
  • Posted on Dec 19, 2012
Vivitar Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428823
Points
622693
What type and size memory card?
I am getting memory card error with canon powershot a410
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
When i click a picture it takes lot of time 2 save the picture even if the card is not full.. like e.g i click the birthday blowing of candle i cannot instantly take picture of the cutting of the cake....
It is possible that the memory card is full, with little space for storage. Also it can have errors if the card was not cleared or formated.
So ideally it will be best to remove the card and use an adaptor to load into your PC, open and copy all the image files to a selected marked folder . Now after the images are saved you can scan the mamory card check the properties. Now you can get an idea of the card but it is best to have the card FORMATTED. This will wipe the memory clean and make it work faster on the camera. If not the camera processor has some errors.
3helpful
New 4GB SDHC mamory card will not work in my Samsung NV3 camera - I get a memory full message. I have formatted the card and erased internal memory with the card out of the camera and still no joy - any...
Sorry, but your older camera can only use 2GB or less standard SD cards. Fortunately, these are relatively inexpensive these days, and may be found on Amazon, if your local store no longer carries them.
I have just gotten it and it says memory is full How can that be? Can I clear the mamory? I haven't taken many pictures.
just had someone tell me to take the memory card out, turn on your computer, delete the pictures on your internal memory and then put your memory card back in. Make sure you know where your pictures are stored in your computer before you delete something you may want.
2answers
Did this camera come with a disk for my computer? It is my kids and I don't know.... I purchased a memory card and it still says.. memory full please insert card. can you take pictures w/no memory card?
Here is a link to the user's manual for your camera:
http://vivitar.com/products/13/VC8025%20User%20Manual.pdf
It mentions a CD with a program you can use to manage your programs, but to me, it doesn't sound necessary to be able to get photos off your card.
If it is a brand new card, look at it before you put it into the camera to see if you might have accidentally put it in locked mode. If it is unlocked, see if you can format the card from within the camera (refer to p. 23-24 of the manual).
If it is not a new card, connect the camera to a computer and see if you can download any pictures already on the camera, and clear the card out.
And no, you will not be able to take pictures without a memory card.
Good luck, and feel free to ask for more help.
1helpful
Card locked
SD cards have a slide switch along one edge. Slide it toward the contacts to enable write, away from the contacts to protect.
Kodakeasyshare c160 says memory card full with only 5 pics on a 16G card. Any ideas?
Pull the pictures off the card then plug it into the computer if you have a SD card port. Then go into my computer and find the card icon. right click on the card and pick properties. Verify that the card is showing as a 16GB card and how much available memory is available on the card. It should show 16GB. If the card does not try and run a format on the card and see if that fixes it. Five pictures on the highest resoloution on your camera should not fill up a 16GB card. There might be files stored on the card causing the issue or the card might be defective.
Cannot take pictures anymore and lost my pictures in memory card.
Hi , the only remedy to remove write proctection is to transfer or download all pictures to computer or rewritetable cd,
Format the sim card and donnot set again to write protection the picture .
Protect are located in play menu ,navigate downward you can see protect .
2answers
Troubleshooting
By Pressing The Button which takes picture a red light which will measure light appears this will consume a lot of battery try charging the battery to full extend
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
