Question about John Deere 22HP VTwin 48" Riding Mower
John deere 145 toe in adjustment
Toe in adjustment
Posted by jeff tillman on
tom walsh
    Sergeant:
  • 226 Answers
Adjust by measuring between the wheels {metal rim} at the 9 and 3 o'clock positions. I.e, halfway point on the rim at the front and rear. You can measure between the tire, but it is more difficult to get a good, repeatable measurement. If it were an MTD, you could adjust the toe by bending the tie rod/ drag link.
tom
Posted on Dec 19, 2012
  • 1 more comment
  • jeff tillman Dec 20, 2012
    Thanks Tom. However...it doesn't appear that there is a way to adjust the toe-in on my JD 145. The tie-rods are not threaded at all - just solid. Since they are toed out so bad, I could just bend the tie-rod some more - maybe I'll give that a shot?
  • tom walsh Dec 20, 2012
    If they are toed out, your tie rod is likely bent. Remove it, and whang it with a hammer on concrete to straighten it out.
  • jeff tillman Dec 21, 2012
    I'll give it a shot - thank you for the input.
4 Related Answers
Anonymous
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
Mike Squire
  • 420 Answers
SOURCE: how to ajust drive belt 145 john deere
It is better to replace and not adjust the wheel drive belt, too loose and it slips, too tight and you ruin very expensive bearings YOU can not replace...Belts are cheap, bearings are very expensive!
Posted on Jul 23, 2010
dcramer531
Dcramer531
  • 1654 Answers
SOURCE: When I go to engage the blades on my John Deere
How excatly does it shut down? does it slowly bog down or immediatly shut down? Does the belts squeel when you engage them? Things to check are the reverse, and seat safety switches if it shuts down immediatly or a pinched or twisted belt along with pulleys that may be bound up and frozen.
Posted on Apr 17, 2011
george boren
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
My front wheels are toeing put I replaced the left spindle and that was out the problem what could it be
Toeing means toeing in or out at the front compared to the rear of the front tires To adjust this you loosen the lock nuts at the tie rod where the ends screw on and adjust it longer or shorter depending which way you toeing
May 24, 2015 | Garden
Toe in & toe out pajero sport dakar
The correct adjustment of 'toe' is vital to the safe operation of the steering. Adjusting it requires specialist equipment or a full understanding of what you are doing.
As most tyre fitting workshops will adjust steering geometry very cheaply it is not worth getting it wrong by trying it yourself.
Jun 04, 2014 | 1988 Mitsubishi Pajero
Front Wheel Allignment
On these LH body cars, camber is not adjustable. Neither is caster. Those angles are preset by the suspension geometry. However, specifications for them ARE published. Generally, if either of those two parameters are out of spec, then it's likely something is worn or damaged and needs to be replaced.
The only adjustable parameters are to the front and rear toe but specified as "Total Toe" - see note below.
The alignment specs are as follows ...
ALIGNMENT SPECIFICATIONS AT VEHICLE CURB HEIGHT
A. FRONT WHEELS
  1. CAMBER
    Acceptable -0.6° to +0.6°
    Preferred +0.0°
    Side to Side Differential
    Acceptable 0.7° or less
    Preferred 0.0°
  2. TOTAL TOE - Specified in degrees. See Note Below
    Acceptable 0.4° in -to- 0.0° out
    Preferred 0.2° in
  3. CASTER* (reference angle)
    Acceptable +2.0° -to- +4.0°
    Preferred +3.0°
    *Side to Side Caster Difference not to exceed
    Acceptable 1.0° or less
    Preferred 0.0°
B. REAR WHEELS
  1. CAMBER
    Acceptable -0.6° -to- +0.4°
    Preferred +0.1°
  2. TOTAL TOE** - Specified in degrees. See Note Below.
    Acceptable 0.2° out -to- 0.4° in
    Preferred -0.1° in
    **TOE OUT when backed onto alignment rack is TOE IN when driving.
  3. THRUST ANGLE
    Acceptable -0.15° -to- +0.15°
Note: "Total Toe" is the arithmetic sum of the left and right Toe settings. Positive is Toe-in. Negative is Toe-out. Total Toe must be equally split between left and right wheels. Left and Right Toe must be equal to within 0.02° (2 one hundredths of a degree).
Courtesy RJK & Concorde Shop Manual
Mar 08, 2014 | 1994 Chrysler Concorde
What is a total toe adjustment sleeve on a 2006 f 250
There are two sleeves. One that adjusts total toe and one that adjusts the steering wheel. When you turn the total toe sleeve, it will push both wheels away causing more positive toe or pull them in causing more negative toe. You get total toe where you want it and then you set the steering wheel straight using the second sleeve.
Mar 31, 2012 | 2006 Ford F-250 Super Duty
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 | Garden
Atomic 4tix 310 binding toe adjustment.
Did you ever figure out how to adjust the toe piece? I am having the same problem
Mar 08, 2010 | Sport & Outdoor - Others
Wear on the inside of front tires
Toe, I believe is tires pointed in or out like your toes. Caster, think about the casters on furniture that want to point straight in the direction of travel. Here is a good reference: http://www.aa1car.com/library/wheel_alignment.htm
What you are describing could be a toe in, toe out problem or it could be weak springs or overload condition.
If the guy/girl that told you there was no toe adjustment was a front end alignment mechanic, I would be inclined to believe them. If you have not spoken to a front end mechanic, you should.
Thanks for your question at FixYa.com
Feb 11, 2010 | 1999 Dodge Ram
Drivers rear wheel toe's out at top how do i make adjustment
There are shims that can be moved but unless thaqt car never went outside the will be probley frozen.Is it the toe that is off or the camber you said out at the top,that sounds like camber adjustment.
Apr 02, 2009 | 1985 Chevrolet Corvette
Wheel alignment
The main cause of steering wheel off-center is toe misalignment or rear axle misalignment. Toe can fall out of adjustment fairly easily as a result of daily driving, so you can imagine the effects of pounding it through 4WD trails on a regular basis.
Toe is designed to preload the steering linkage to remove play in the system. You can visualize toe angle from above; toe-in, or positive toe, is displayed when the leading edges of the tires are closer together than in the rear. Toe-out, or negative toe, is when the leading edges are farther apart. Zero toe is when wheels are pointed straight ahead and are parallel to each other. A slight amount of positive toe is preferred for most vehicles.
Improper toe angle isn't the only reason a steering wheel won't center. This phenomenon can also be caused by the steering linkage not being centered when toe was adjusted in the first place. This can be corrected by recentering the steering wheel and readjusting toe to proper specs. A bent steering arm or linkage component can also cause the steering wheel to be off-center. I've also seen this occur due to loose steering arm bolts. An off-center steering wheel contributes to tire wear because as the wheels are turned off dead center they turn toe out and increase tire scrubbing.
Sometimes an off-center steering wheel is accompanied by a wheel pull to one direction or the other and could be the result of a damaged component somewhere in the vehicle - a bent axlehousing could be throwing off the rear toe setting (rear toe setting is often overlooked). A bent frame or overly worn suspension bushings can also be the cause. If your wheel is off-center and also pulling, it can be as simple as incorrect tire pressure from side to side. Memory steer is another effect that is usually associated with an off-center steering wheel. This is when the steering wheel returns to an off-center position and can result in steering pull or drift after completing a turn. This can be caused by binding in the steering linkage as well as power steering system issues such as leaks or improper hydraulic pressure. Steering linkage bind occurs when proper geometry is not maintained in lifted vehicles.
Many 4x4s don't have factory provisions for adjusting caster and camber and rear toe and camber, but the front toe setting is easily adjusted. Toe is controlled by the steering linkage. By loosening the adjusters on the tie rod and shortening or lengthening the tie rod by turning the ends, toe angle can be adjusted. This should not be a substitute for regular professional wheel alignment jobs and is simply a tip that can be used to put off frequent trips to the alignment shop due to regular trips to the trail.
Before determining toe angle and/or performing adjustments, it's a good idea to start the engine and turn the steering wheel side to side to relieve pressure in the system. Then, turn the wheels straight and shut off the engine. You should also roll the vehicle back and forth a few times between measurements.
Get someone to hold the other end of the measuring tape and measure the leading toe distance. This is the distance between the leading edges of the front tires. You'll compare the results to the distance between the trailing edges of the tires directly opposite from where you took the first measurement.
The higher number will indicate toe direction: higher number in leading edge indicates toe out; higher number at trailing edge displays toe in. Larger-than-stock tires require more positive toe for best results.
Once the necessary measurements are performed to determine what the current toe setting is, you can loosen the bolts on the tie-rod adjuster sleeve so that the tie-rod ends can be rotated. Don't forgot to tighten the adjusters when you're done as damage or injury could result.
The tie-rod ends thread into the tie rod. The ends can be threaded in or out of the tie rod to make the assembly longer or shorter. Longer creates more toe out; shorter toe in. Don't make huge adjustments all at once. It's best to adjust and measure a few times to achieve appropriate setting.
I hope this helps you if you were looking to do a toe alignment yourself if you have decent knowledge of component location on a jeep.
Jan 30, 2009 | 1995 Jeep Grand Cherokee
John Deere 22HP VTwin 48" Riding Mower Logo
958 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
