Print Shop Pro Publisher version 11 was built for Platform OS: Windows 98 / Me / 95. It is an old software which is not for Windows 7(x86 or x64) OS. This is due to software compatibility issues with Windows 7 ie an old software running on a newer OS Platform.
You have to get a newer version which is compatible with Win 7.
I would try re-installing the operating system. Try out Windows 7 or Windows XP if you want a windows machine or Linux Mint if your prefer Linux. Linux Mint is free here http://www.linuxmint.com/
lot os unlock sourse avail across the globe,inorder to that i found a free unlock guide site where u will get free guidance http://www.mobileunlockguide.com/
In this industry it is always a hardware or software. But if your PC does not allow you to get into windows without going into safe mode it was probably due to a bad driver installed, but you must determine that driver. So look into your mind and find out what you loaded last onto your pc with drivers. If you can remember delete that from your system while in safe mode. But only if you remember do not speculate. In order to remove software you need to get into control panel
Click on start
Then locate Control Panel
Then locate Add/remove software
Locate the software you recently put on your computer
Unistall it
Reboot PC
This will hopefully fix the problem!
In my experience usually a reload of the OS and all program fixes this problem, the other fix is by shear luck you find the right software to remove it.
Reinstalling OS and programs is really simple. First try the software removal if this does not help contact me I will walk you through OS reinstall!
