Question about Lenovo TopSeller ThinkCentre M90z AIO Core i3 530 293GHz3GB500GBDVDRW23FHDbgnGigNICW7P PC Desktop
ThinkCentre M90z lock menu problem
On the desk top a window pops up saying menu is locked then it another pops up saying menu is unlocked
Posted by oscar on
max carson
  • Lenovo Master
  • 7,627 Answers
What menu? What does the pop up say? Just " lock menu"?
Posted on Dec 19, 2012
How do I unlock the security lock on the stand from the desk.
Hi
go on setting and reset all setting. it will come on normal mood.
May 25, 2016 | Sony SDM M81 18.1" LCD Monitor
Computer says its locked; change users, but my mouse is locked up too.Im using my desk top to contact you.
You can use the windows key to open the start menu, then use your arrow keys to hightight turn off your computer, hit the enter key, use your arrow keys to highlight restart and hit your enter key This will restart your computer and hopefully, unlock your mouse.
Let me know if this solution works for you. If all else fails, it is acceptable to push the power button until the computer turns off, then hit it again the turn the computer back on. This is not the normally acceptable procedure for shutting windows down, but in this case, it can be done without any negative repercussions.
Brian
Jan 02, 2011 | Computers & Internet
Please help me to fix pc registry problem for window xp please
First try to do a System Restore.
  1. Open the start menu and click all programs.
  2. Go to Accessories.
  3. Go to System Tools.
  4. Then choose System Restore from that menu.
  5. When System Restore opens choose Restore my computer to an earlier time and hit next.
  6. On the calender see if you can pick a time before you started having problems. Choose that day and click next. It will run and should reboot the PC. It might take a little bit just let it do its thing.
If that doesn't work try this.
Open the My Computer icon on you desk top. If you don't see it on your desk top it will be in the start menu on right side of menu. Left click to open it. A window will pop up that show your drives (C:), (D:) and so on. Right click on the (C:) drive choose Properties from the drop down menu. The next window will have some tabs on the top. It will look something like this.
Click the Tools tab. There will be an option to Check Now. Click it and put a check in both little boxes and click the start button. It will say the PC needs to restart to preform this task. Restart the PC and walk away till it gets done.
Hope this helps.
Good Luck
cookEmonster
Oct 16, 2010 | Computers & Internet
My Maxtor 4 500 GB hard drive sounds like it's trying to run, but then it says that It's not connected to my computer. The little front light is lit up, but then it says it's not connected to my laptop. ...
This could be something as simple as the cable has gone bad. I would replace it first. If that does not work try this.
1.Right click the My Computer icon on desk top. If you do not have My Computer on the desk top it can be found in the Start Menu. It may just say Computer.
2.After right clicking it go to Properties in the drop down menu and left click it. You will get a window looking like this.
If you have Vista. I think Windows 7 is similar. Windows XP will be a window with tabs at top.
3.Open the Device Manager and you will get a window with a list of devices that are installed on you
PC. Looking like this.
In the list you should see your Maxtor it's probably down in the USB section. If you can't find it, it means you need to reinstall the drivers. If you do find it right click on it. You will have a drop down menu with different options on it. You can try uninstalling it reboot the PC and see if it auto finds it.
Hope this was helpful.
Good Luck
cookEmonster
Oct 13, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Samtron 56v monitor control is locked
hold the menu button for 10-15 seconds.this shld unlock the menu. if the menu window still keeps popping up then u shld change either memory ic or power regulator..
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Mar 28, 2009 | Philips 170S7FS 17" LCD Monitor
When logging into windows vista, screen says locked. Once I type password in the desk top appears briefly and then goes back to login screen
Boot up your PC then when the bios screen disappears press F8 (to give you menu options like safe mode) one of these options is a vista repair option.....choose that and your pc should boot into windows properly....I believe this is a corrupt winlogon.exe....
Dec 06, 2008 | Computers & Internet
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
that depends on the brand and model of monitor ,
it normally takes 2 buttons pushed at same time to unlock it.
if you have side buttons its normally them.
May 12, 2008 | Gateway FPD2275W LCD Monitor
Lenovo TopSeller ThinkCentre M90z AIO Core i3 530 293GHz3GB500GBDVDRW23FHDbgnGigNICW7P PC Desktop Logo
607 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
