At times my space bar and enter key works and at times it does not. It is currently working and it will soon stop working. It started when i was first in a game it stopped working all of a sudden and i tried using spacebar and enter in google chrome which also did not work
There is a metal bar on the space bar key that needs to be attached to the key board. It is really easy if you look at the keyboard you will notice at the ends of the empty space two metal loops one on either side. the metal ends of the key actually have to go through the loops for the space bar the be fully functional if the metal bar's ends are not through these to distribute the pressure of your finger only the middle of the key will work. Hope this helps.
Wet replace keyboard
SOURCE: keyboard space bar
turn your keyboard upside down and tap it a few times. if that doesnt solve the problem repeat.
If it still won't work write back for more ideas.
good luck and please rate my answer. thanks.
SOURCE: took spacebar off to clean up a pop spill...metal bar NOT attatch
There might be a metal wire if it is missing, which snaps to the keyboard, you may need a new keyboard.
If you are unsure, you should probably thake it to your local computer repair shop.
Good Luck.
SOURCE: the enter key of my laptop sudden stopping working?
To find out if it is a hardware or software issue, try going into the BIOS (Shutdown laptop>Powerup laptop>Immediately after pressing the power button tap the F2 or Del keys).
Once in the BIOS see if you can navigate to change settings with the enter key. If you can then there is a problem with your accessibility options in windows or keyboard driver. If not then you will need to take your laptop into a service centre for them to replace your keyboard.
Thanks
C
SOURCE: Dell Inspiron 1545 space bar, ''n'' and ''b'' keys suddnly don't work
There isn't any "Known Issues" that I am aware of with that model. Try re-seating the keyboard cable, see if there is any difference:
http://support.dell.com/support/edocs/systems/ins1545/en/SM/keyboard.htm#wp1179891
If no difference, contact Dell if under warranty. If not new keyboards are about $20 on EBay
and it amazingly when one of it stops working, both of them stops working
thanks guys
sflr
