Question about Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME
Peerless faucet Model P88100LF has a broken clip that attaches/secures the spray hose underneath the sink. ? any replacement clips w/o buying the entire faucet?
3 Related Answers
Anonymous
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
plumbiseasy
  • 11 Answers
SOURCE: Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
Posted on Jun 28, 2009
Randy Marshall
  • 349 Answers
SOURCE: Do I have to remove
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Posted on Feb 14, 2011
How do I replace the sprayhead?
replace the sprayhead Dragon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kitchen Sink Faucets How to Remove the Spray Head From Sink
How to Repair Single Handle Kitchen Faucet With Spray Hose Kitchen Plumbing
Pull Out Kitchen Faucet Sprayhead Replacement
Replacing the Kitchen Sink Spray Nozzle
May 25, 2016 | Plumbing
How do I connect the sprayer hose on single sprayer faucet ,peerless style, the pin wont go in?
What is the model number of the faucet? There was no attached pictures to this submission.
Jun 14, 2014 | Delta Faucet DELTA/PEERLESS FAUCET CO....
How do I disconnect the pull down hose?
if you were able to snap the water lines from shutoffs onto the faucet with a click, look for a small wire clip inserted into the lower/outer half of the joint. TURN OFF THE WATER, then remove the wire clip carefully and the water supply lines should come back apart. the little wire clip goes back into the slot for safekeeping till next time .
Jul 09, 2013 | Peerless Industries Peerless& Single...
I need to change pullout sprayer hose how to do that
if it is a quick connect hose squeeze the push in clip together and pull it out and pull hose off. then do that in reverse.
Dec 03, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have a faucet/sprayer combo and the hose came off when I was using it and now I can't seem to thread it back up....what do I use/do? p.s. I don't know what brand or model...just had to pick something so...
Disconnect hose from sprayer unscrew nut on sprayer head remove washers and you will see a small c shaped clip get that apart then remove hose and thread it back on under sink and feed it back up through sink and reconnect to sprayer
Oct 28, 2009 | Delta 2402 Classic Single Handle Kitchen...
Need to buy a peerless wall mount kitchen faucet P 99305 from :[email protected] need help!
Peerless happens to be a less than preferred brand. If you go to www.peerless.com, you will find the model type. Try it, you may be able to order it online. haven't seen it around.
good luck.
Oct 09, 2009 | Peerless Industries Peerless Wall Mount...
Kitchen sink side spray clips/couplings don't match any replacement parts
First off I would put this issue at the top of my to do list because the laminate flooring will not hold up at all with a constant water bath. That being said, turn off the water to this faucet and remove the entire faucet. Take it to a hardware store or hardware department of a box store and see if the broken part can be replaced. If yes, good. If no, replace the faucet as this is a lot cheaper than replacing the laminate floor. Good luck
Jan 05, 2009 | Home
Blanco side sprayer fell off the hose
If the sprayer fell off the hose and you see no threads to screw it back on with, then the retainer clip has gone bad. Unscrew the sprayer at the bottom of the piece that came off the hose. There should be a little metal clip. That clip holds the sprayer on the hose. If the clip came off once it will again. Buy a new sprayer assembly with a new clip, unless someone has one sitting around.
Please rate this response and good luck, Phil
Dec 28, 2008 | Blanco Essence Kitchen Faucet with Side...
Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME Logo
123 people viewed this question
Top Delta Faucet Plumbing Experts
Muntejaya Ginting
Muntejaya Ginting
Bill Johnson
Marvin
Marvin
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
