Measuring Tools & Sensors Logo
Question about Black & Decker Measuring Tools & Sensors
I have a MacAllister double bevel slide mitre saw 1800w, the motor works but does not connect to the saw blade, where can I get a spare part for it?
Blade 305mm, Bore 30mm
5 Related Answers
Anonymous
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
Rob Bridges
  • 41 Answers
SOURCE: wobely blade
sounds like the bearing is going out on the blade shaft
Posted on Feb 13, 2009
Anonymous
  • 31 Answers
SOURCE: Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Posted on Mar 24, 2009
Editor925
Dean
  • 285 Answers
SOURCE: How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: I have a 12
The commutator is dirty. Take a light grade sand paper and slip it in the opening and turn the motor by hand while you clean the comm with the paper. Fold the sand paper or put it on a stick so you can make contact to clean the comm.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
WHERE CAN I BUY SUITABLE ARMATURE FOR macallister DOUBLE BEVEL SLIDE METRE SAW cod305dlsm
from the manufacturer of the motor spares department
the motor will have a manufacturers name on the specs tag
Jun 22, 2018 • Saws
Tooltec 1800w mitre saw all I did was change the blade and now the saw is dead
Does the motor hum when you pull the trigger? If so, check that the push tab for securing the shaft from turning while changing the blade is pulled out all the way. Sometimes fine saw dust can get inside and prevent the spring from pushing the tab back out all the way. If there is no hum, check the power source.
Mar 23, 2017 • Blade Saws
Macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Feb 26, 2012 • Saws
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
1helpful
Looking for help scouts have a carpentry merit badge from the 50s they talk about using a BEVEl and a Miter tools can you help
The bevel is an angle fiding tool. it consists of a wooden section about 4" long with a swivel bolt at one end connected to a slotted metal blade (similar to a 1 foot steel ruler). The bolt has a wing nut and bolt to allow loosenig to allow the blade to rotate and slide to the required angle where it is locked into position using the wing nut.
The mitre is a wooden block with slots cut into it at pre determined angles. ie 45 degrees. When cutting a mitre joint the wood is placed against the block and the saw follows the line of the slot cutting the 45 degree angle.
Hope this makes sense and good luck
3helpful
2answers
Hi, my dewalt 12 inch double bevel, is making a
This sounds like a problem with the electric brake on the motor.
Wobely blade
Top Black & Decker Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
