SOURCE: monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
SOURCE: MAG Innovision LT1919WDb flat screen goes black
I had the same problem. I contact the manufactuer and they refused to fix it. They said it would cost an additional $100 to have it fixed. I have not even had it a year. I thought products sold in America were suppose to last longer than a year? What has happened to companies standing behind there products. Beware of this monitor!!! DO NOT BUY IT!!! LT1919WDB
SOURCE: inverter board for mag innovision monitor
Hi...there,
It's seems you need a new backlight inverter. The one you had have a burnt out capicators. You can either replaced yourself or order a new one. Good lucks!
SOURCE: How to disassemble Mag innovision 19" monitor
Once the 4 screw at the bottom of the screen has been removed the frame surrounding the lcd should slide up and away. The display itself is fastened to the plastic back by 6/8 screws be careful when removing the lcd screen since it is still attached to the electronics in the back by cable connectors!
SOURCE: mag innovision 786n winxp driver download
DriverGuide.com claims that the driver is available here
http://members.driverguide.com/driver/detail.php?driverid=489569
for US$2,99.
There is an "universal driver" also here:
http://www.edriverdownload.com/driver/MAG%20InnoVision%20/MAG%20InnoVision%20all%20crt%20models%20Driver.html
