SOURCE: ariston washing machine error message
PUMP WASH BLOCKED WITH A SMALL PIECE OF CLOTHING UNBLOCKED AND MACHINE WORKS FINE
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
SOURCE: error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
SOURCE: f-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
