Question about 3M (EP7630AVR) Video Capture
Dont know how to make a latch hook pillow - 3M (EP7630AVR) Video Capture
Tip
Unthawing the water dispenser in the freezer door
If the icemaker is loaded with ice or certain areas of the freezer are perhaps overloaded redirecting cold air toward the water output it can freeze. Also if the ICE shoot has ice cubes obscuring it's closure that area gets cold enough to freeze the water. Check after dispensing ice that the round flap is closed.
I open the freezer door and place three regular sized bed pillows placed into white trash bags into the opening being sure to DEPRESS the light latch with one of the pillow placements so it won't constantly sound a door ajar warning.
I then close the door as much as the pillows will allow and place a chair in front to keep the pillows in place for about 25 minutes. Usually this will do it and the water will begin to flow . I draw off enough to run it completely through the entire line . Sometimes a small piece of ice will come out. I had tried hair dryers and all manner of things and just gave this a shot one day and it works when it freezes for whatever reason it will use.
on Apr 26, 2015 | Frigidaire Gallery GHSC39ETJB 22.6 Cu. Ft....
The latch on the laptop broke How do i open it?
you need to mimic what the latch did most latches are like arrows in this case get two thin items ( blunt butter knifes) and move the latches both left or right if its a middle type latch then try pushing in were the broken latch was .get what i mean if the old latch pushed in then its a middle latch if it slide then is double arrow latch ounce the laptop is open if you dont want to spend $$ fixing the lach just cut of the locking arrows to stop it locking again
good luck
email me if need further assistance
Jun 25, 2010 | HP Pavilion dv1000 Notebook
How does the door linkage work i.e a diagram
There are plastic connectors that attach to the rod and attach to the latch. The rod usually hooks into the inside latch, the rod may be held to the door by some clips. Then the rod connects to the latch with a plastic retainer clip.
Mar 13, 2010 | 1993 Honda Civic 4 Door
My door latch will not lock in to place. It is below freezing and I dont know if the door is broke or the latch is just stuck
Likely it's just stuck. Spray it with wd 40 or other solvent and make sure the latch hook is open. If it's not, pull the door release handle (like you are opening the door) and gently pry the hook back to the open position.
Dec 10, 2009 | 2006 Jeep Wrangler
Can't get the tailgate open on my 1998 Jeep Grand Cherokee
I had the same problem. I was able to get the back window open.
I took the the 4 screws off that are on top of the inside of the door (where the tailgate window latch is).
Got a metal coat hanger. straightened it and made a hook at one end.
carefully pushed the plastic part of the tailgate towards the inside
slid the coat hanger straight down (to the level of the tailgate key/handle) to catch the door latch from the inside and pulled up.
that will get the tailgate open.
then you need to take the rest of the screws out of the lower part of the tailgate to get at the latch assembly. Carefully take the plastic off.
(you will need to take the nice black insulation stuff off the metal part of the door carefully so you can replace it and tape it up if necessary after fixing the latch.)
peel the insulation off the metal part of the door, you will see the assembly rod has come off the latch and will need putting back in place and a little sqweeze to stay on.
really bad design I guess, but since I fixed it at 140000, I haven't had any trouble with it at 166000.
Feb 26, 2009 | 1998 Jeep Grand Cherokee
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Neck pillow Question
J Pillow is the best-selling travel pillow and the winner of British Invention of the Year in 2013. Read why this is the best comfortable neck pillow you can use on the go. Pillow Review with Pros and Cons
Aug 27, 2008 | Conair Nm6s Body Benefits Vibrating Neck...
Pillow support
Memory foam neck pillows come in many varying densities, sizes and shapes. Usually, when you seek out a chart for memory foam pillows, they give you suggestions based on your height only. While that is a good start, you need to also consider the following: Do you sleep on your side, back, stomach or a combination of all three? Do you prefer a small, medium or large pillow now? What kind of pillow are you used to sleeping on? Is it firm, medium or soft? Do you suffer from neck pain? Knowing the answer to these questions will help you in selecting the right memory foam pillow, or may suggest that you would prefer a different pillow altogether. For example, if you sleep on your stomach, a neck pillow might not work at all. You might want to check out a memory foam pillow that's shaped like the standard pillows we all grew up using.
Aug 27, 2008 | Brookstone Theraspa Turbo Massager
3M (EP7630AVR) Video Capture Logo
Top 3M Televison & Video Experts
Marvin
Marvin
Are you a 3M Televison and Video Expert? Answer questions, earn points and help others
