Will be in the back of the SUV for 4 hours.. May not fit if it needs to stay up right. Main concern is to prevent compressor oil from leaking out. Any other tips on moving it to new location would be appreciated. Thanks,
SOURCE: I am looking for a schematic for the kenmore 51 lbs ice maker
If you are saying that the icemaker is filling with too much water and spilling water into the freezer then probably yout icemaker module is bad, Also make sure there is no ice inthe fill cup of the icemaker.
SOURCE: Kenmore - ice maker won't produce but water in door fine
Most of the times the solenoid ( electric valve that lets water from the line when the ice maker calls for it) leaks and this little water freezes up inside the filling tube for the ice maker , in tnis case the solenoid has to be replaced.
Testimonial: "I was able to verify that the solenoid was working correctly and that the water supply to the Ice Maker is sound. Do I replace the entire ice maker? "
