Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon mp520 makes a horrible noise and displays code 5100
I replaced one of the color cartridge and now it makes a HORRIBLE squeaky-grinding noise when the cartridge "base" resets. Then it gives me the error code: 5100 and says to restart and if that doesn't work to look at the manual. The manual says call canon - ugh!! Even removing the cartridge and restarting the printer doesn't fix it.
Posted by erica berrios on
Smith William
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Canon Expert
  • 241 Answers
Canon printer is one of the best brands in the world many big organisation are relying on the canon printer, its unmatched printing quality and versatility makes it more best printing devices in the world, but every machinery devices causes problem, but don't worry we have a proper solution, Kindly visit us to get the proper solution
How We Support:
100% Fully Assistance
We Are Available 24*7
We Work Fast as per Customer demand
For More Info Do Visit Us: canon printers error code 5100
Toll-Free No: +1-888-633-7151
Posted on Sep 12, 2019
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: MP150 Error code 4 and 5
Don't use refill cartridges, because it will damage your printer someday. and will cost your parts as brand new. so better use the original ink.
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Posted on Feb 11, 2008
Anonymous
SOURCE: SERVICE ERROR 6000
Use this:
1. Turn off printer
2. Hold down Resume button and press Power button
3. Keep holding down Power button and let Resume button go
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more
8. Your printer should respond as normal.
Posted on May 20, 2008
Robert Kitaji
  • 1335 Answers
SOURCE: Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
Posted on May 05, 2009
Anonymous
  • 68 Answers
SOURCE: printer won't accept cartridge
i sure u buy wrong cartridge for your MP450...if u want higher quality, u should buy CL-51 cartridge for colour and CL-50 for black..
fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
http://www.canon.com.my/section/inkjetPrinter/supplies/
hope this help... ; )
Posted on May 26, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Posted on Dec 13, 2009
Showtime Ronco rotisserie & bbq oven makes loud grinding squeaky noise while rotating. Can I use WD 40 to oil the gears?
No, it is petroleum based and highly inflammable. Use a good quality plant based oil like Sunflower Oil.
Jan 18, 2017 | Ronco Kitchen Appliances - Others
My hp 3500 is making a sqeaky noise before it prints. the page comes our beautifully but the noise is disturbing.
I have found these printers to be noisy at the best of times, but bad cartridges can add another level of noise to things. Squeaky cartridges are not uncommon, particularily if they are remanufactured cartridges and not orignal HP products.
May 04, 2011 | HP Color LaserJet 3500 Printer
The screen color started flashing funny. I turned the TV off. When I turned it back on, it makes a horrible groaning almost grinding noise, on and off, then finally stops trying to do what ever it's trying...
This tv have a colors wheel,it dying,now it dead.Colors flashes black&white and grinding noises,the colors wheel was spinning off of it motor axis and rubbing it sides wall.The colors wheel,now require changing to make the tv work again.The colors wheel it pretty hard to replaced,because it require take out many machanicals parts even can get to the colors wheel to replaced it.Best it to hire a tv tech. to do the job.If u never done or change anythings,that require take out alots and many machanicals parts before.
Oct 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Rear-end grinding noise in 1993 GMC Sierra 1500
your description sounds like the gears inside the the same differential you just replaced.
Oct 13, 2009 | 1993 GMC Sierra K1500
Hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Jun 15, 2009 | HP DeskJet 882c InkJet Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Refilled cartridge, still says it needs to be replaced...
If you let the cartridge run totally dry then they need to be reset or replaced, I have tried purchasing reset software myself and found then to be a waist of money as they do not reset the cartridge at all. Do yourself a favor and replace the cartridge and remember to top up the cartridges before they get half empty.
May 08, 2009 | Lexmark X2600 InkJet Printer
Horrible grinding noise
The problem sounds like a broken or stripped gear in the printer. If the unit is under warranty I would contact the authorized repair station for that printer in your local area.
Nov 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
216 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
