Question about Pioneer Sx 780 Stereo Receiver
No sound output from turntable on sx-780 receiver
I connected my turntable to my receiver but no sound! Everything else works like AM FM sound and I have even been able to connect my portable cd player! I 'd like to listen to my old albums
Posted by otto Kirpitnik on
  • otto Kirpitnik Dec 18, 2012
    I have sound from all other sources except from the Phono (turntable) if it is a fuse wouldn't it blow everything.
    PS I will not get rid of this receiver as it has served me well since I bought it for $350 in 1978 or 79. New receivers often do not have a phono input for my Turntable.
Mike Meder
    Sergeant:
  • 259 Answers
Do you have in connected to a phono input? be sure you haven't connected it to another input..........turntables are low-level (20ma) output, cannoit drive high-level input (200ma).........good success, meder's tv service
Posted on Dec 18, 2012
2 Related Answers
Sam
  • 3247 Answers
SOURCE: My Pioneer Receiver (SX-255R) won't
Just to be sure we are talking the same unit I have included the link to the user manual for SX-255R
http://www.pioneernz.co.nz/Site/Pronto/Files/user_manuals/SX255R%20USER%20MANUAL.PDF
Suggestions
1. have you tried to press the Muting button on the remote unit.
(item 11 remote unit diagram)? does it make any diffrence - what if the button is stuck?
2. Have you tried to play the Tuner radio - what happens then? do you still get Muting.
3. You mentioned something about speaker wire coming out.
I understand that Pioneer receivers shut off if any of the speakers is faulty, ie, correct impedance is not showing at the speaker input point.
Usually the newer units give an "overload" message. It is possible this could be happening and the SX-255R gives the "muting" message instead. Some people have reported very minute shorts where strands of the speaker wire touch the body and it causes "overload".
One way to check is to remove speakers wires one by one and see if the "muting" goes away. Then you can check the offending speaker if that is what is happening.
Good luck
Please do drop a comment to say how you progressed.
Posted on Jan 02, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Can I connect my pioneer SX-255R stereo receiver
Yes, but it depends on your laptop hardware and software. We'd need to know a lot more about that side.
Posted on Jan 21, 2010
Our turntable is not producing any sound even though we have changed the speakers
Be sure the audio-out leads are connected properly to the receiver. They usually will work ok connected to the aux. plugs. Be sure the selector on the front of receiver is set to aux as well. Check the cartridge output wires to insure they are connected to the cartridge ok. If you have the receiver powered up and have the proper settings on the front of the receiver, you should get a little static sound when plugging the audio output leads into their respective input jacks on the receiver.
Feb 21, 2015 | Audio Players & Recorders
How do i hook up an antenna to the pioneer sx-950
There are two antenna sources on the Pioneer SX-950.
Both of these outputs are located on the rear panel of the receiver. The AM is a permanent mount. The FM is standard RF/Coax which will run to your antenna.
Antenna Inputs: FM 75 ohm, FM 300 ohm
Am Ferrite Bar Antenna
Hope this helps,
TechGuy21
A
s
Jul 04, 2011 | Audio Players & Recorders
My Pioneer SX-780 Receiver has very low volume and distorted. Are the output IC Amps bad? They use (2) STK-0050
A little more triage would be in order before you take a knife to it. What source(s) produce the distorted sound? How about test tones? Same? It's sick. Not same? Something else is going on. Have you referred to the manual(s)?
Apr 07, 2011 | Pioneer VSX-D457 Receiver
Electronic hum
Hey there,
What I think is the problem here is that your A/V receiver may have a blown preamp for the turntable input. Or, although less likely, assuming that both channels sound normal when the receiver is set to a different input such as an FM tuner, there could be an impedance mis-match between the turntable's output and the reciever's input. But, the goal is to try simpler (and much more inexpensive), methods first. Try replacing the cable that connects your turntable to the receiver. If no difference is heard, then we should take another diagnoses.
Regards,
Hortona
Mar 25, 2009 | Pioneer Audio Players & Recorders
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
Connecting Pioneer SX-737 Receiver to computer problems
I've been recording LPs for over a year now.
I've got the turntable outputs plugged into the phono inputs on the receiver amp.
I'm taking the Y cord (pair of RCA connectors at one end, mini plug at other) from the Tape Record (these are what you'd use to send a signal to the tape deck for recording) on the amp to the "line in" on the sound card. You may want to look up the specs on your sound card to make certain that you've got the plug in the correct socket. There may be a "line in" and a "microphone" socket. Use the "line in"
What recording software are you using? Audacity is free and is ok. I'm using Goldwave (costs ~$50) and highly recommend it. MUCH better than any other package I've tried. Just google "goldwave" to find it.
The recording software should have an option for selecting / specifying a source. If you have "microphone" selected and the y cord going into the "line in" socket, yoiu won't get anything.
Dec 20, 2008 | Audio Players & Recorders
How to hook up my turntable to my RCA home entertainment system
http://www.htfr.com/more-info/?catno=MR155277.
please buy the item above -----connect your turntable to input and take the output and connect it in line in in receiver.
Aug 11, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Mar 07, 2008 | Audio Players & Recorders
Pioneer Sx 780 Stereo Receiver Logo
Top Pioneer Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Jax Planet
Jax Planet
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
