I've had a Canoscan lide 700f for a few years and never had any issues with it until now. I only really use it to scan negatives (35mm ) but it's no longer working. Scanning a normal doc works fine but when I try to scan a negative it tells me it can't detect anything. The film adapter unit appears to be lighting up as expected and looks like it's trying to scan the neg. Any idea what's wrong with it?
Hello try to reinstall the software for the scanner from here:
http://www.usa.canon.com/cusa/consumer/products/scanners/film_negative_scanners/canoscan_lide_700f#DriversAndSoftware
Please select your windows system 32 or 64 bit.
Download the driver and uninstall the old software before you install the new.
Canon does make an driver upgrade once a while to fix previous problems with the software.
Hope this will help you
SOURCE: Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
SOURCE: 35mm slide and negative adapter
First option would be the manufacturer, second would be EBAY for either the part, or a used unit with the part.
Just wanted to add that I get the error not matter which negative I use, even ones that were scanning fine the day before.
