Computers & Internet Logo
Question about LaCie Computers & Internet
What voltage is my hard drive
I bought a LaCie external hard drive in the USA in 1996 (plus or minus one year). I now live in Australia. I'm trying to find out whether it runs on 240V as well as 110V, or whether I'll need a step down transformer. The drive has nothing written on the outside of it, no serial number that I can find, but it does say FCC ID: GZJ-QDRIVEII and copyright 1994. It has SCSI connectors.
Posted by Rob Pensalfini on
5 Related Answers
Anonymous
SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Posted on Jun 10, 2007
Anonymous
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Posted on Sep 08, 2008
Anonymous
SOURCE: What power supply does Lacie 160GB external hard drive use?
Although not sold at Best Buy™, there are available adapters/cables to make this transfer possible. I recommend using a search engine to find "firewire to usb." Hopefully this will give you the results you need.
Rhiecksboy
Posted on Oct 15, 2008
Anonymous
  • 10865 Answers
SOURCE: Francis Francis X3 voltage
hello. The electrical power used in most of Japan is very similar to that of the USA. The difference is that Japan uses 100 volts as opposed to our 110. Therefore, most electrical appliances, blow dryers, etc will work equally well in Japan and in the USA.
Since you are in Australia now, use the same adapter for your expresso machine as you use for other small appliances and you should be fine.
Posted on Sep 13, 2009
EsWorld
Ernest R
  • 1618 Answers
Easiest way to tell is to open the machine and look at the pump or other electrical parts they will have a voltage rating stamped on them.
Posted on Sep 17, 2009
3helpful
2answers
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
I bought a few years ago a Lacie d2 safe hard drive with AES Encryption (with biometric fingerprint sensor). Currently not my Toshiba desktop or IBM laptop pick up the hard drive when I switch it on. The...
Hi... Problem with your external hard drive, pc don't recognize it...
it possible you have bad sector in your disk drive, or your usb cable is not responding.... the best way to find out open your box then take off our hard drive and install it into a pc and see if the hard drive work... or you box it self the controller inside our external box maybe damage,
Not turning on.... I turned it off to move its location and now i cant turn it on...Power cable and everything is in place and live, but no joy..
Same problem. Bought a new power supply at extortionate price from Lacie but still no joy. I'm hoping to find a way of converting to a dumb external USB HD.
Lacie External Hard Drive FAILED
Just format the drive and u will be able to use it.
2helpful
I have lost the external power supply for my 1TB laCie (300797U). I have another power supply that has physically the right connector, but I'm not sure if the voltages are right. The supply I have is a...
The voltages are right because hard drives use 12volts for the motor drive and 5volts for the digital logic circuits.
The only thing I don't know is the correct voltages for the various pins, there is a possibility it may not suit the LaCie.
This maybe a standard configuration for external USB hard drives, you need to check with LaCie.
Plus de lecture sur mon MAC
LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Disque dur
Je un ne sais pas exactement ce que vous faites référence en ce qui concerne la
fonctionnalités de votre Lacie avec votre Mac, comme je l'aurais plus besoin de détails
de vous. Mais, au moins à vous diriger dans la bonne direction.
Tout d'abord voici le lien pour votre externe LaCie USB 2.0 500 Gig
Disque dur pour plus de soutien de LaCie:
Lien:
* LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Hard Drive Support
En outre, si, pour plus de soutien pour des problèmes avec ce disque dur, y compris si nécessaire d'avoir à reformater votre disque dur, voici le lien:
Plus de dépannage pour votre LaCie externe USB 2.0 500 Go HD pour Mac.
Si vous avez besoin davantage d'aide, laissez-nous savoir si ces liens de soutien ne permet pas de résoudre votre problème actuel avec LaCie. également fournir des précisions sur la question, afin que nous puissions mieux vous aider.
Observe,
-Mactechtrainer
2helpful
2answers
My LaCie is not recognized by my computer, makes a clicking noise when it tries to start up. I've used this external hard drive for several years with no problems.
It has most probably just reached its "end of life". Several years for a hard drive reading and writing is a good track record.
You can probably take the casing apart and replace the hard drive. Just make sure that this is an USB 2.0 interface before spending the money.
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mounting an external hard drive onto my I Mac
Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
Top LaCie Computers & Internet Experts
Marvin
Marvin
shadow
Mike
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
