Question about Casio FX991MS Scientific Calculator
Find out 25 % 2 = ?
For example 26 % 12 = ?
Posted by bhagyashr48 on
  • bhagyashr48
    bhagyashr48 Dec 18, 2012
    on casio fx-991ms calculator...
k24674
  • Casio Master
  • 8,091 Answers
12*26/100=12*0.26=3.12
25% of 2 Press 2, multiplication sign, then 25 [SHIFT][(][=]
Posted on Dec 20, 2012
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
My casio fx-82ms does not work when i use the 100% option ... example if i do 0.25 / 100% i would not give me the correct answer in stead of 25 it gives me o.25 .
100% is the same thing as 1, so .25 / 100% is the same as .25 / 1, which is 0.25 as the calculator shows. Why do you think it should be 25 and not 0.25?
Sep 28, 2013 | Casio FX82MS Scientific Calculator
I want to build a scale model of my house
o determine ANY scale you divide the actual measurement, in inches, millimeters, or miles, by the denominator in the fraction. for example:
25 inches in 1/25 scale is 1 inch. (you divide the 25 inches by the denominator in 1/25....25.) 25 divided by 25=1
Jan 10, 2013 | Crafts & Hobbies
IQ SOLVED 5*5=2030,3*5=1220,5*3=?
2012 is answer
(5) square = 25 , 25-5 = 20 , (5)square = 25 , 25+5 = 30 so == 2030, (3)square = 9 , 9+3 = 12, (5)square = 25 , 25-5 = 20 so == 1220, now
5) square = 25 ., 25-5 = 20, 3)square = 9 , 9+3 = 12
the +,-,+,- series is continued.
Apr 12, 2012 | Vivendi [email protected] Mathematics Study Skills...
25 is 62.5% of 40 what are the step by step process
There are no unknowns in this question, but the step by step process for interpreting the words are:
1)' 25 is' means 25 =
2)' 62.5%' means 62.5/100, so 25 = 62.5/100
3)' of' means denominator of subject (which is the 25), so:
25/40 = 62.5/100.
This might be easier to see if there were an unknown. For example: 25 is what percent of 40? Using the above interpretation, this becomes:
25/40 = x/100 then solve for x.
Or, another example: 25 is 62.5% of what?
25/x = 62.5/100
Sep 27, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
Hello we have a Brother 2820 Fax Machine and we cannot find the Instruction Manual and we need to reset the time can you please advise us on how to do it. Thanks Marie
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format. Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Apr 07, 2011 | Brother Office Equipment & Supplies
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
Using the percent key...for example finding 25% of 120.
To calculate 25% of 120, press 1 2 0 * 2 5 SHIFT [%]
Sep 09, 2010 | DateXX DS700C Calculator
Change the date and time
1 Press Menu/Set, 0, 2.
Press Menu/Set.
Press Menu/Set.
or 10 for October.)
Press Menu/Set.
Press Menu/Set.
6 Press Stop/Exit.
mode.
LCD shows Sleep.
Jun 25, 2010 | Brother MFC-7220 All-In-One Laser Printer
Casio FX991MS Scientific Calculator Logo
27 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
