Question about Laser 3115cn All-In-One Printer
Weak vertical line in text - Laser 3115cn All-In-One Printer
Posted by marcel el koubi on
Rich Varsay
  • 826 Answers
It may be cartridge problem.Take a look at the cartridge and see if you can see toner on the cartridge.
To do this, remove the cartridge and pull down the face plate. Look at the cartridge inside and see if there is toner lines on the cartridge. If so, it is likely time to replace the cartridge. This should not happen but it does happen time to time.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Dec 18, 2012
How to print in vertical text mode
i dont know if i get the question right, but try to press the Style button and then move the cursor to the style that looks like "--" or "_". then pres the enter.
Sep 19, 2011 | Dymo LetraTag QX50 Thermal Label Printer
The picture is larger than the screen. I cannot see all of the text at the top or bottom of the screen.
this is called over voltage in vertical . some
WEGA serise have ADJ for this when the
vertical chip / or a cap gets weak.
the adj is in side the tv sorry
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Vertical green line in papers
Your printer green cartridge drum cleaning blade is weak.you change it than solve it
May 30, 2009 | HP Color LaserJet 2600n Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Vertical lines on image background
Try cleaning and aligning the print heads from the properties menu in the control panel
May 22, 2008 | Canon BubbleJet i560 InkJet Printer
Laser 3115cn All-In-One Printer Logo
21 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
