I'm at college and I have my xbox hooked up via the component cables. It was working before winter break but now its not. I had the tv unplugged over break
When the tv is on but the xbox is off, the box that floats accross the screen reads "NO SIGNAL". When I turn my xbox on, it changes and reads "NO SUPPORT"
Any Ideas?
thanks,
J
note:
When I use the standard red, white, yellow cables it works fine on the composite input, and I was changing the xbox output between hdtv and tv when i was testing it.
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
SOURCE: No sound on my 32'' Insignia LCD HDTV
I have a question? Do you move your Television frequently, OR do you unplug it frequently when it's not in use? I have found that doing either or both of those things can bring on problems, especially audio problems.
I've had the disappearing sound problem twice with my Element FLX-2610. This latest time I was stumped because the full scan didn't resolve the problem. And of course, the sparse manual that comes with the TV contains no troubleshooting advice at all.
But I did find a suggestion on another sveral other sites: Reset the TV. You might have a small reset button (like you would find on a DSL modem) somewhere on your TV but there is a manual way to do it two. Whichever way you do, MAKE SURE to disconnect every single device (yep, it's a pain) and UNPLUG the TV before doing this.
To reset with a reset button, disconnect devices and unplug the TV. Depress the reset button for 5 seconds. Reconnect devices, then plug in the TV.
Manual Procedure:
Disconnect all devices
Unplug the Television
Using the on/off button on the Television (NOT on the remote), depress and hold the button for 5 seconds.
Reconnect the devices, then plug in the TV.
Unless something has shorted out or burned up inside, this resetting, as a last resort, should fix the audio problem. Worked like a charm for me!
Good Luck!
Nena
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
SOURCE: I hook up my tv cable to the Component 1, and it works
make sure you are using component video red green blue cables for video and not just the yellow composite video cable not sure if this helps you but good luck
