2000 Volkswagen Jetta TDI Logo
Anonymous Posted on Jan 14, 2009
2000 jetta gls
Heat gets slightly warm when idling, but immediatly gets cohoses are ld when i start driving. The temperature gauge will rise just a little when its idling, but totaly drops afer I start driving. The thermostat has been replaced and all hoses are warm when idling.
  • rjd55 Jan 16, 2009
    Car barely warms up but when I start driving the temp gauge goes down to next to nothing.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
1935
Points
7
Some times new thermostat are bad . try a new one but hotter 195* or better
Idles high when cold 2004 jetta 1.8 t
This is normal. The ECM monitors engine temperature and increases idle when it sees the engine is cold. The ECM sets the idle back to normal when engine temperature rises.
Temperature gauge cold then back to normal
You have to make sure the thermostat is working properly and is the correct one. Idle the vehicle for about 20 minutes and then feel the upper radiator hose. It should be hot to the touch. Drive the vehicle and when the temp gauge falls to 'cold' stop and feel it again. If it is much cooler to the touch than before the thermostat is defective or wrong.
2000 gmc safari warm up questions
Your thermostat may be stuck in the open position. The original thermostat is a 195 degree. Your engine should be warm enough to blow heat in 5 minutes of idling or driving.
2000 Jetta GLS 2.0 Overheating
Sounds like you got a bad thermostat.
Car getting hot
1) Is there enough coolant in the radiator?
2) Have you noticed if the electric fans are kicking on when the temp is going high? I'm guessing that they are not, the temp switch may be faulty.
1helpful
My temperature gauge read red... the light came on and I turned the heater on to try to help it cool down,it worked, but there was no heat coming from the vents. when i turn the heat off, temp rises...
Have you checked the coolant level? If it is low, what you describe will happen, the engine will run hot, and the heat won't seem to work (coolant level too low to circulate through the heater core). Hope it's that simple, if not, let me know and I'll attempt to help further. Good luck!
3helpful
Slightly overheating while at idle and heater on low or off.
The thermostat is starting to stick .
Replace the thermostat.
2004 Tahoe Heater Problem
check coolant level ,must be low ,chck for coolant loss
2answers
Heater not working
vacuum to blend doors cancels when engine uses it upon acceleration... there is a check valve that could have failed there at vacuum lines to blend doors .good luck
Inconsistent heat.
The first thing i would do is replace thermostat and bleed cooling system, then re-check, It sounds like you have a defective thermostat.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
