Can cannon mx 410 fax be used with voip, cannot receive/dispatch the fax
SOURCE: CANT SEND FAX THRU MY CANON MP830
you need to setup and set data for send and receive to be the same to use the same port!!!
SOURCE: CANT SEND FAX THRU VOIP LINE
Make sure baud rate is set to 9600 and error correction mode (ECM) is off. If this does not correct your issue then you may have to contact your provider to adjust your sample rate (packetization). This adjusts the size of the packets and is often a common fix. You may want to run a ping/tracert from command prompt to check for latency and/or packet loss with your ISP. I'm a voip tech and these are the primary fixes for fax issues.
SOURCE: faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
SOURCE: MX 308 do not give the fax receive tone
i have not canon printer mx308 driver so plz help me
