Question about Magic Sing Along Consumer Microphone
My husband tried everything, but it is so confusing, so much cables input/output, please help. Please note that the Magic Sing is the newest version and is equipped for HDTV.
Which version did you buy? the latest version is ET23KH. I am on the waiting list at love2karaoke because the hindi version has not been released yet.
I used to have the ET19KV and my friend has ET18K, which are older models 2011 and 2009 respectively.
ET23KH supports HDMI connection with the cables included so that problem u should not have.
Which model do u got?
Posted on Jan 30, 2013
SOURCE: magic (karaoke) mic sound delay problem when connected to HDTV
Ok..I found a workable solution. Essentially using my HDTV only for the lyrics(video output) and using a RCA to stereo mini plug cable to send the sound output to my amplifier that has a analog stereo input. Works like magic. No delay. It went from being unusable to WOW!
Posted on Aug 28, 2009
SOURCE: 2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Posted on Sep 17, 2009
SOURCE: Magic Sing EG-18000 Microphone Delay
1.
have the delay.
**TVs
SOURCE: magic sing ET18K delay problem
The instruction manual should have a calibration section. If not, you can probably find the instructions at the manufacturer's website.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Posted on Feb 11, 2011
