Question about Polder Traffic Light Kitchen Timer- White
The display is okay but minute/sec buttons not working. Any suggestions?
Posted by jodyburgin on
Gene Haynes
  • Polder Master
  • 5,391 Answers
Reset timer?
1) Copy following links to identify same-similar timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) Add comment and describe timer in detail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Dec 18, 2012
PS3 won't reset
are you trying to get to the safe mode menu?...if so unplug for 1 minute...replug...hold power button (beep) 5 secs next beep is 1...next beep is 2 after 5 secs and power off. let go of button...repush power button(hold)...(beep)...then beep again after 5 secs...then 2 fast beeps...let go of power button. it will ask you to connect your USB to your controller then push the PS button on your controller. you should be in the menu for safe mode.(research your options there thru sony and understand what they are first before running them!)
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
How to set time of day clock on 2007 1200n
Turn the key to ACC,
press the button on back of speedo several times until time is displayed,
press and hold for 5 sec, 12HR begins to blink,
press and release to switch between time formats,
press and hold for 5 sec, hours will blink,
press and release repeatedly to set hrs,
press and hold for 5 sec to get blinking minutes,
set minutes similar way,
press and hold for 5 sec to save, when minutes stop blinking the time is set,
turn the key to off.
Jul 27, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
How do i reset the time clock ?
press and hold menu button for 2 secs the display shows adjust clock with hours flashing press the seek/tuning buttons to adjust to change hours press menu button briefly to get minutes flashing adjust mins to exit press any button or wait 4 secs
Apr 17, 2009 | 2000 Jaguar S-Type
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Setting The Clock
Set the display to time by pressing the tittle button. once time is displayed, press tittle button and hold until the time starts blinking. now adjust hour using arrow keys. now press mode once and use arrow keys for adjusting minutes. press mode again. now the time is set.
Alex Victor
Jul 01, 2008 | Alpine CDE-9841 CD Player
Polder Traffic Light Kitchen Timer- White Logo
53 people viewed this question
Top Polder Hardware & Accessories Experts
Gene Haynes
Terry
Terry
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Polder Hardware and Accessory Expert? Answer questions, earn points and help others
