Tascam Pocketstudio 5 MP3 Player Logo
Question about Tascam Pocketstudio 5 MP3 Player
How to use bouncing on the pocketstudio 5
How to use the boucing
Posted by tim burt on
HiTi P110S PocketStudio Photo Printer does not work with Mac 10.7?
Apple has a habit of dropping older printers with their newer operating systems. Check the printers website for a solution and maybe try the driver from a newer model.
How do know if I should replace my struts on my 2001 saturn sl1 with 98000 miles. there is no apparent problem but the repair place i went to said that it was time to replace them.
if the front end bounces allot on the freeway then the struts are worn out, many shops sell struts based on 60,000 miles as the time for out with the old and in with the new, if u feel the car rides well and doesn't bouce excessively then don't replace them, it is very expensive.
PocketStudio 5 Error - encDSP Init Err
I turned off the unit, then while holding down rew and record buttons at same time, turned on unit. I don't know why, but it worked.
Revs boucing
try to add some lucas aditive to it, if does not solve the problem then your reverse might be about to brake, but this lucas aditive try to add with a transmission tune up at same time
1helpful
Pocketstudio 5
A CF card is a compact flash memory card. It's rectangular and has two rows of holes along one side which fit over the connector pins when you slide the card into its socket. Compact flash cards can be bought from electronics or photographic shops, and some department stores. They are not expensive but these days they are usually 1Gb and up. The TASCAM Pocketstudio 5 can only format up to 128Mb so most of a modern card is not used but the card will still work.
Not recognized by computer
http://www.tascam.com/Products/PocketStudio5.html There is a menu on the left with all the documentation, as well as downloads of their software updates. This product is discontinued, so no further support will be available from the manufacturer.
3helpful
2answers
Compact flash cards
what is the solution for this problem posted by tiller on Sep 26 2006
Top Tascam Audio Players & Recorders Experts
Morne Olivier
Morne Olivier
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
