Question about HP DeskJet F4280 All In One Printer InkJet
Cannot print Avery labels 8160 with proper spacing on HP Deskjet F4280
I have selected the appropriate Avery template of 5160 and when I test print on plain paper everything looks right. However, when I put in the label paper, the top spacing is incorrect, and therefore ruins the rest of the labels on the page. Any tips? On the back of the actual labels, it says to be sure to switch the printer setting of paper type from plain paper to labels, but my printer properties do not give me that option?
3 Related Answers
Mike Waldron
  • 1019 Answers
SOURCE: Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Posted on Feb 25, 2008
Anonymous
SOURCE: HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Posted on Dec 11, 2008
Mark Gough
  • 415 Answers
SOURCE: My hp officejet J4680c printer and my hp pcs 1315
follo0w the link to avey for further help
http://www.avery.com/avery/en_us/Help-Center/Formatting-and-Printing-Tips/_/Ns=Rank
Posted on Jan 05, 2010
When printing labels (Avery 5160) the labels start being shredded half way through and then the printer jams.
Have you setted up in the printer driver to print on label? the printer will automatically adjust the internal parts for printing on a higher density paper!
If you done it gently remove the Duplexer unit from the behind of the printer and chech for pieces of paper or everything could cause the paper jam!
Hope you found it useful, for futher questions i'm here :)
Dec 07, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
LOOKING FOR TEMPLATE TO PRINT LABELS FOR DIVIDERS; wORD 2010
Hello there :)
Here you are. It would be easier to purchase a product that you can print on; however, you can print these on normal paper and just cut them http://www.avery.com/avery/en_US/Templates-%26-Software/Templates/Dividers
I hope this helps! Thumbs up are always welcome.
May 03, 2011 | Computers & Internet
How do I set up my HP 3050 to print Avery labels 5160?
You need to download the templates they have online and edit them in Microsoft Word. Here is a link to the template:
http://www.avery.com/avery/en_us/Templates-&-Software/Templates/Labels/Address-Labels/Address-Label-30-per-sheet_Microsoft-Word.htm
Click the blue download template button and follow the instructions.
Mar 31, 2011 | Office Equipment & Supplies
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
Jul 30, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How do i print labels using epson r2400 photo printer?
If you are using the Avery template, make sure you change the page setup settings from Manual Front (default) to Default Tray (sheet). Then when it tries to fix the layout, select ignore (on Wrd 2007 anyway). Then select Photo / Glossy paper and hopefully away you go.
Mar 31, 2009 | Epson Stylus Photo R2400 InkJet Printer
Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
Dec 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP DeskJet F4280 All In One Printer InkJet Logo
93 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
