Attempted to charge via socket and USB but still wont turn on. Not so much as a flicker.
SOURCE: w300 WONT TURN ON WONT CHARGE!
i happen to me you need to find a friend or a family that has the same phone that you have and that your problem solve!
SOURCE: Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
SOURCE: i phone non responsive wont charge or turn on
Based on your description, it sounds like this iPhone logic board isn't working properly. It could be related to the power management unit, or the battery could have simply become desoldered if you dropped the unit.
Another cause for this problem could be from water damage which may have fried the PMU chip. If this is the case and you're not experienced with BGA removal/replacing then you're best bet is probably to sell the unit AS IS for parts or repair on eBay, Craigslist, or you could sell it to me.
Hope this helps!
SOURCE: my samsung SGH-J700 wont turn on or charge
Time to get the ribbon cable changed. You can do this yourself with some patience after buying the cable over ebay or get it replaced at a service centre for a very cheap price.
SOURCE: Acer Asipre 5315 laptop wont charge or turn on via
Check ur Laptop Charger (replace it)!
tell me if it helps...! :)
