DONT KNOW THE PROBLEM ENTIRE SCREEN HAS GREEN COLOR. BOTTOM OF SCREEN IS DARKER THAN UPPER PORTION OF SCREEN.
SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever
heard of this? Part runs about 300 bucks. TV is out of warrenty as it
is 2 years old. Do you think it is worth it to fight sony and get them
to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
SOURCE: Sony Grand WEGA KDF-60XS955
I had the same problem and it costs 200.00 dollors for the lamp that bad
SOURCE: Sony Wega KDF-55E2000 won't turn on
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
SOURCE: Sony Wega kdf-55wf655 rear projection set keeps turning on and off
Had exact same problem with my KDF-55WF655 and put in new projection bulb assembly and no more cut out plus picture is much brighter even on standard. Next time will just by bulb and install in old assembly as it looks straight forward now that I know what assembly looks like. Got about 7200 hrs. out of OE projection lamp and almost 4 years service.
SOURCE: Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
