I inherited a Necchi 537 FA. It does not sew well at all. I get repeat loops from the bobbin. I am trying to find out how old it is and if it is worth taking it into a shop to get tuned up. I am not at all opposed to buying a new machine for around $150 if this Necchi is not worth trying to fix. Thoughts?
Necchi's are good sewing machines, I personally own 2 necchi's,
and I've never had any problems with them and I've had them for around 10 years, here is what I suggest
use a new needle--one that is for the fabric your sewing
rethread the machine top and bobbin--use every thread guide
try a different bobbin
clean under the needle plate and in the bobbin area for lint
call a sewing machine repair shop in your area and ask them how
much a necchi sewing machine is worth or check on ebay and see
what they are selling for.
since you inherited the sewing machine,, having the machine
serviced completely would be a good idea, that way they can check
to see if the grease and oil that the gears and parts use is fresh or
needs to be replaced and it's very important the grease and oil are in
good condition.
and they can make sure the machine's is timed correctly
ask how much a tune up cost for a sewing machine and then
you'll have to decide if the price is what you want to pay.
also since the sewing machine is doing repeat loops from the bobbin
adjust the top thread tension just a little at a time till the stitch looks
normal on a scrap piece of fabric
if you don't have a manual on the sewing machine let me know & I'll try
to find you one.
I've been sewing for 30 years, and like I said I have 2 necchi's already
and I had one other one before these 2 that I have now and it lasted me
for around 15 years and I wore it out making clothes.
I wouldn't hesitate to buy or except another necchi because I know
they are good machines.
I have a mechanical and a electronic necchi and my husband uses the
electronic one when he makes quilts.
good luck on your decision
Merry Christmas and A Happy New Year
SOURCE: I have a Necchi 537FA sewing machine. It sill sew
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
SOURCE: Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
SOURCE: necchi sewing machine
i repair a lot of sewing machines as a hobby .. the necchi is one of the better ones .. they are easy to use and work well .. i almost always dontate the repaired machines to places like "womens shelter" .. "home for troubled girls" or just give them to someone that has nothing or cant afford new machines ... it sometimes makes a difference in their life if someone helps them get started .. modern machines vary from really cheap junkers that somehow work to really expensive machines that do everything but are completely out of reach for many.. the old necchis are better than many new machines but no one knows that .. so typically they sell for only $20 to $50 ... but if you donate a working machine to someone it can help, then its worth it weight in gold ..
SOURCE: top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
