Question about Mitsubishi WD62628 62" Projection HDTV
Does lamp for wd57734 fit on wd62628? - Mitsubishi WD62628 62" Projection HDTV
Posted by joseva58 on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
A simple way to maybe know is Google each model number with "lamp" and unless the replacement being sold is exactly the same number they will not work for each other.
Posted on Dec 17, 2012
Wd62628 black lines across screen lamp light stays on
Hello, it sounds like the chip on the dm board is going bad, but a picture of the screen would tell me a lot more....tks
Jan 11, 2015 | Mitsubishi Televison & Video
Replacement lamp won't fit
Look for socket to be bent or moved out of position---happens when replacement lamp is installed.
Nov 06, 2012 | Mitsubishi WD62628 62" Projection HDTV
The lamp light to my WD62628 is on. I'm assuming it needs replacement. Can I do that myself? if so where can I get directions? and where can I get the replacement lamp that won't cost me an arm and a leg?
yes, on the back of the tv is door, open it remove the lamp, do not touch the lamp itself. go online put in the model number of your tv and search for lamps, now make sure when purchasing you order the entire lamp assembly. this is real easy and will save you a ton of money doing it yourself
Aug 12, 2010 | Mitsubishi Televison & Video
I HAVE A MISUBSHI TV MODEL #WD57734. THE TV WENT OUT AND THE LAMP LIGHT CAME ON. i REPLACED THE LAMP AND KNOW THE LAMP LIGHT AND POWER LIGHT ARE BLINKING AND IT WONT TURN ON.
Try resetting the set, there is a reset on the front of the tv where the power button is located, just stick the point of an ink pen it it and it will reset itself, if this does not work make sure the lamp door is secure.
Dec 04, 2009 | Televison & Video
I have a wd62628 Model I have sound but no Pic.
Have you replaced the lamp before? If not, I recommend you do it, since it might be the issue. But if you already replaced it, you might have a ballast issue.
Aug 10, 2009 | Mitsubishi Televison & Video
Mitsubishi tv model wd-62628
It's most probable that you have a ballast issue, it might not have enough power to keep up with the new lamp. That's why you don't get any image.
Aug 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Unit powers up then shuts down
Varify that the lamp door is totaly closed and tight. The door switches do not tell the Main Micro. the door is closed unless door is flush
with rear cabinet.
Hope this helps,
skyassoc
Jun 17, 2009 | Mitsubishi WD62628 62" Projection HDTV
Lamp replacement
on front of tv next to lamp lite need to reset with small pin or paperclip
Nov 06, 2008 | Mitsubishi WD62628 62" Projection HDTV
Lamp just blew
if you have experience in electronic repairing why not! but if not! dont do that! coz that is sensitve intalling and they have high voltage to harm you! get authorised tecnician for best result. havce a good day!!!
Sep 14, 2007 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi WD62628 62" Projection HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
