Question about Sony KP-53S65 53" Rear Projection Television
I have tried unplugging it for 15 seconds, still flashing.
It probably was a bad product. Call sony and they should send you a replacement depending on how old your product is.
Posted on Dec 17, 2012
SOURCE: standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Posted on Feb 08, 2007
SOURCE: tv went black and no sound standby light falsh twice and paused and flashed twice again
This indicates a short happened somewhere in the set, causing the set to go into "safe mode" where it won't let itself turn on. Oftentimes it's the convergence board. Depending on what that will cost you, you may want to just replace the set.
Posted on Mar 25, 2008
SOURCE: Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Posted on Oct 21, 2008
SOURCE: Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Posted on Nov 09, 2008
SOURCE: standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Posted on Jan 18, 2009
Feb 08, 2011 | LG 37LC7D 37 in. LCD HDTV
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sep 29, 2010 | Sony KP-61V85 61" Rear Projection...
Feb 20, 2010 | Samsung Propel A767 Cell Phone
Jun 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Mar 21, 2009 | Panasonic Televison & Video
Feb 28, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
44 people viewed this question
