Question about Lanier Office Equipment & Supplies
Lanier 5627 ADF not working. Does not recognize paper
The ADF stopped working. When you open the top, you normally get a series of beeps - that no longer happens. When you insert paper into the ADF, you normally get a beep, that no longer happens. When you try to copy with the ADF it copies from the Scanner glass even though there is no paper on the scanner glass. What could be wrong?
Posted by grantjm1 on
4 Related Answers
Anonymous
  • 11 Answers
SOURCE: copier stopped working - has ADF jam message
As mentioned in the other thread concerning this problem, the board seems not the problem.
I had the same problem and found out, that the cable connecting ADF and "main machine" was the problem. In this cable are 10 wires, one of them - in my case the violet one - was broken.
I used a new wire and soldered it in between, now it works fine.
I think - as this very short cable is only plugged on both sides (ADF side under the cover) - you should check this first. Spare - part should be much cheaper.
An other soultion can be, that the sensor - hook slid out of his mount.
Hope this helps
Posted on Sep 17, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: ADF not working
Open the document feeder and look for an obstruction.
Clean the roller and pad with isopropyl alcohol.
Also look for a switch actuator trapped down or knocked off.
Posted on Jan 04, 2009
Pdsco
Otulagun D. O.
  • 129 Answers
SOURCE: I can not copy from
Is your system on? If it is on, then you press copy, it scans it and a window showing your scanned document is displayed. Then from here (the system) you can print it. Try it and tell me what happens.
Posted on Dec 08, 2010
Joed911
JDTec
  • 4338 Answers
SOURCE: officejet 7310xi- when i try
This is usually a bad scanner... follow the instructions on this HP link to diagnose the problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587971&cc=us&lc=en&dlc=en&product=391182&tmp_track_link=ot_search
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 28, 2011
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
Panasonic DP 2500 photocopy machine from you a few months ago. I cleared a few paper jams and have not had a problem until now. The message on the machine says to ?close the ADF cover?. I do not know what...
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
Jul 22, 2010 | Panasonic Workio DP-2500E Copier
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
It stopped faxing through the feeder and said feeder errror. its a HP j4680 all in one office jet
Hello, Brittany.
Give this a try (from HP Support):
Complete the following steps to check the condition of the paper, reload the original, and then open and close the Automatic Document Feeder cover.
The main reason for this issue is that the ADF rollers that pick up the papers might not grip the paper because dirt sticks to the rollers.
Step One: Check the paper and reload the original
The condition of the paper, or the amount of paper, might prevent the ADF from picking it up and feeding it through the product.
1. Make sure that the ADF tray contains fewer than 25 sheets of paper.
2. Make sure that the ADF tray contains no photo paper or carbon paper.
3. Make sure the paper in the ADF tray meets the following criteria:
* No curls, folds, creases, or tears
* No staples or clips attached
NOTE: Folded paper, torn paper, or paper with rough edges might not feed correctly. If your original is folded or damaged, either reprint the original or try to smooth out the damaged portions.
4. Reload your original, with the print side up, into the ADF tray. Place the pages so that the top edge of the document goes in first. Slide the paper into the ADF tray until you hear a beep or see a message on the display indicating that the loaded pages are detected.
* If still a problem, go to the next step.
Step Two: Open and close the ADF cover
NOTE: Remove all originals from the ADF tray before you open the ADF cover.
1. Open the ADF cover, and then close it again.
2. Press the OK button.
Follow these steps to turn the product off and then on again.
1. Press the Power button to turn off the product.
2. Wait 15 seconds.
3. Press the Power button to turn on the product.
Hope this helps.
Feb 26, 2010 | HP Office Equipment & Supplies
Error "paper jammed in ADF" no paper is jammed. Can I reset this message.Cant use printer.
The small lever inside the housing on top gets jammed, you have to insert and remove paper repeatedly to free it up, try this a few times to see if "adf" on the screen disappears. If not look into top and try playing with the lever manually, or let a page jam and then open outer housing.
Jan 08, 2010 | Epson Stylus CX9400 Photo Printer
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
Bell & Howell 2000d fb adf tray will not go down after scanning
It may be the clutch on the left side of the ADF. there are 2 there, one does the pick roller the other the tray. you could try swapping them over and see what happens.
also the sensor sometimes sees the underside of the top of the ADF and thinks its more paper, therefore keeping the tray up. try running a perment black pen around the inside of the hole in the tray where you put the paper to stop too much light getting in. (dont colour in the sensor itself though!)
Sep 04, 2009 | Bell & Howell FB Series 2000D Flatbed...
Users Manual
the ADF is the automatic document feeder the part on top of the machine that you insert the paper to Automatically feed the paper in one at a time, there may already be a document on the glass lift the top and put it back down it should clear
Jul 31, 2008 | Canon PC-1060 Black and White Copier
54 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
