I have bought and replaced the complete pump assembly. I have installed the new unit and I am getting the code F2 after I start it. Help!!!!!
Assuming you have a drawer unit, the F2 eror means there is some erro in the pump motor circuit. It is likely the motor speed sensor may be faulty or dirty. Please provide full model number so that I can check which part I am mentioning. May I ask why you needed to replace the pump assembly in the first place.
SOURCE: Fisher & Paykel Dishdrawer DD603H.
Hi F2 error is displayed when control won't sense motor to be
rotating, usually occurs due to frozen/bad motor or stuck motor rotor or the
RPS sensor or a bad stator assembly. If the motor rotor spins freely and both
impellers are securely attached then the issue is with the RPS sensor. If the
motor won't rotate then it is the motor rotor that has to be replaced. Hope
this helps...please post back for further assistance. Daniel
SOURCE: there is an error code f2. How can I fix this?
The F2 code= siezed pump. To check remove all the dishes followed by the grey dish wrack wedged in the bottom. Lift off the plastic spray arm to reveal a grey plastic ring around the outside of the stainless mesh, and you will also see the blue plastic impeller. Turn this anti clockwise and lift out the whole stainless mesh cover. Then there is a brownish ring with the blue pump impeller on top. Turn this anticlockwise and the pump should lift straight up and out. The impeller may have come off and lifted off with it the brown ring leaving the rest of the pump stuck in the hole. So be careful here, get it out without damaging the housing it fits into. Replace the motor/impeller unit and off you go. Yours could just be stuck of course. A clean may do the same trick.
