Question about Panasonic PT-AE700U Multimedia Projector
My Panasonic wont display picture only flashes. YPbPr
    Champion:
  • Panasonic Expert
  • 225 Answers
What type of input cable are you using. YPbPr is a three or five wire hookup red, green, and blue.
Posted on Dec 17, 2012
Anonymous
SOURCE:
How do I get the date/timestamp to display on pictures with Panasonic Lumix DMC-ZS8?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 30, 2013 | Panasonic Lumix DMC-ZS8 14.1 Megapixel...
Picture won't display. YPbPr is flashing on screen
go to settings and select the computer mode instead of YPbPr
the image from the computer will be seen
Dec 16, 2012 | Panasonic PT-AE700U Multimedia Projector
Sound comes on, no picture and YPBPR:3 coe comes up
tried with other component input like AV1 or AV2 doesn't work?.ok turn off the tv and unplugged it for a while to reset the power supply board.
Sep 23, 2012 | Hitachi 55HDS69 55 in. Plasma Television
SCEPTRE X320BV i HAVE PICTURE ON YpbPR BUT NO SOUND/I HAVE SOUND IF IT'S TURNED ON AV
Connect the same input device to some other TV and check. Connect some other device with composite connections and check the TV.
Aug 06, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
I have changed the setings some how i have disabled some thing now my set top box wont work its a aiko stb255 when i switched it on it just flashes up for a second and then its just a blank screen i cant...
As the manual says "please make sure your TV set can support Progressive format before you select YPbPr Mode or you will can not see picture on TVset" (sic).
To get back from a blank screen:
1 unplug the STB to reset the menu positions to default (because you will be making menu selections blind)
2 plug unit back in and turn it on and use the remote to press in order:
Menu (TV sound will be muted because the menu is now displayed, even though you cannot see it)
Down
Down
Enter
Down
Enter
Down
Down
Down
Right (or Left)
You should then get a picture. Leave the picture setting at CVBS (and don't touch it again lol)
For visual cues on what you are trying to do, look at page 8 of the manual.
Feb 06, 2010 | Televison & Video
Split screen
just open the menu and go to tv settings then adjust it to interlace mode.or use your component input if your tv has an ability to receive a YPBPR input much clear than an ordinary video.
Sep 24, 2009 | Televison & Video
Picture went to all pink but menu is in full color if bypass hd inputs picture is fine and using rca cables picture is fine its just the component connections that turn screen all pink
Your output device is likely trying to send out a YPbPr signal. On the output device try switching it to an automatic mode ideally or manually switching it to RGB. On the PS3 it is under the Video Settings section (Not the display settings.)
Jul 20, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
Jun 17, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Black & white picture
YPbPr refers to the 3 wire component cables designed for HD presentation. These would be RCA type (red, green and blue coponents). 'One" can assume that your DVD is currently set up for HD but you do not have the proper cables attached.
Apr 23, 2008 | Insignia NS-DVDR1 DVD Recorder
Panasonic PT-AE700U Multimedia Projector Logo
141 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
