Question about Leviton Electrical Supplies
Replacing a Leviton 6842 dimmer
How to rewire a defective dimmer switch
Posted by Robert Smith on
5 Related Answers
ashburton
  • 417 Answers
SOURCE: leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Posted on Nov 03, 2008
boomanfoo
  • 23 Answers
SOURCE: Light dimmer issue
the light on the switch does not men it is wired correctly, it only means that you have supplied power at that point. Without knowing more its hard to say, but I'll assume this is a single switch operating a single unit. That being the case, and depending on your fixture, occassionally wires must be grouped together on the switch side. Also quite often these switches are simply defective, and must be returned. If you think you have it correct then its probably a bad switch.
Posted on Jun 17, 2009
Hippy_dd
  • 112 Answers
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
Posted on Aug 21, 2009
Anonymous
SOURCE: Leviton Dimmer Switch wiring and
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Posted on May 20, 2010
gotgeek2
Bob
  • 565 Answers
SOURCE: I just installed a Leviton
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Posted on Dec 22, 2010
How to change the headlight dimmer switch that is located at the lower end of the steering column?
The head light dimmer switch is inside the turn signal switch. If you have a switch below that, some one just rewired it.
May 28, 2016 | 1999 Pontiac Bonneville
Wiring diagram to rewire
I think this is what you are looking for.
Jul 01, 2013 | Gardner Bender Gsw-34 3 Speed Pull Chain...
Lutron Dimmer: 'IN' does not always equal "ON"
These are probably three-way switches being used as two-way. If so, then the switches will have three terminals, but only use two. Just switch one of your wires to the other terminal. If the light will not light, that was the wrong wire. Don't mess with it without turning off the breaker! Good luck.
Feb 25, 2013 | Lutron LG-600P Lumea Single-pole 600 Watts...
I want to "gang" two of these dimmers. I removed the old switches and now I'm staring at a lot of wires! Help me not get electrocuted, please.
If you did not label the wires as to which terminals of which switch before you disconnected them, no one will be able to help you from here. This will require a visit by an electrician to look at and make some tests to determine how to rewire the switches. Sorry!
Oct 19, 2012 | RTO Leviton IPI10-1LX IllumaTech 1000-Watt...
I have installed dimmer switches in the living room. They started off reasonably bright, but after time the maximum brightness is considerably reduced. I have replaced one of the dimmer switches, which...
when you dim a light it increases the resistance,when you increase resistance it causes heat, the more watts you are trying to dim the more heat you create, heat will cause anything to break down, so add up all your light bulbs and make sure your dimmer can handle that many watts, use lower wattage bulbs and maybe a higher wattage dimmer
Dec 30, 2009 | Electrical Supplies
I'm attempting to wire a 3 way switch with a dimmer
Hello Chris,
What has happened, is that you've got th two "traavelers" reversed on the plain toggle switch. These are the RED and BLACK wires. turn off the power and reverse the position of these wires and the switch should work correctly from either the Dimmer switch or the plain switch.
Here's a link with a diagram, which might not exactly match your circuit configuration, but you can also watch a short video that explains how 3-way switches work.
It is just a matter of getting the travelers on the correct screws in order for the circuit to operate properly from either switch. Also, depending on the type of dimmer you've installed, the other switch will only turn the lights on at the dimmer setting that you've left the dimmer switch in. So be sure that you're not turning the dimmer all the way down before you shut it off (at the dimmer) otherwise, the other 3-way switch won't be able to turn the lights on, regardless of whether you've got the travelers in the correct locations.
Remember to turn the power off to the circuit you're working on while you rewire it and flip the breaker back on when you're done.
http://www.electrical-online.com/3waydiagram.htm
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Lutron Dimmers S103PNL 1000W 3-Way, Preset...
Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Oct 27, 2009 | Lutron Maestro 600-Watt Multi-location...
Wiring p fan speed cotrol switch
most common fanlight control is 2 dimmer switches in parallel to control fan spped and light, direction is still usually controlled on the fan body
requires 3 wire in the light box, and a compund dimmer, this one has left and right and fits a single switch box
where a fanlight is used to replace a regular household fitting there is often only 2 wire in the switch box, either a sparky can fishtape an extra cable along the lamp cable, or replace the wire,
the 3 wires from the fanlight are light fan and neutral
some new retrofit fanlights have remote controls to negate rewiring
Apr 26, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Electrical Supplies Logo
1,119 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
