Power indicator light on front flashing yellow
Means the laptop is dirty inside, AND the Thermal Paste compound on the Processor, may have dried up.
(Graphics chipset too, if it has one. Otherwise it is part of the processor. Integrated Graphics)
Fan running continuously means the Processor is overheating.
Like I said; dirty computer inside, and dried up Thermal Paste.
Now,...........if you post the laptop manufacturer, and model number; you will get detailed info on repairing; and not this generic cr@p.
Model number is on the Bottom of the laptop.
Post back in a Comment.
Regards,
joecoolvette
SOURCE: computer wont start
I ran into the same problem with my Armada E500. In my case, it was a faulty RAM module. What I would suggest is start by removing the battery, and the charger. Then continue by removing the plastic section above your keyboard (there is a single screw holding it in place on the rear end of the laptop. This plastic covers the right-hand hindge) from there, there are four plastic tabs that you slide down to remove the keyboard. This will give you clear access to the ram. Remove the module(s) and, using a soft eraser, gently clean the contacts. If your laptop has two sticks of ram, I would also recommend putting them in opposite ram slots. After that, replace the keyboard and plastic bezzel, reconnect the battery and charger, and try to boot it up again
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
SOURCE: my acer one netbook won't boot
This is a common problem with the Acer Aspire one. Apparently, the BIOS needs to be flashed using a flash disk with the required files.
Unfortunately, the files are not available at any website but you can take the Aspire one to any Acer service center and they should be able to flash the BIOS for you free of cost.
SOURCE: my everex stepnote wont turn on, fan runs but it wont boot
I have a Everex StepNote Laptop VA4101M. Model Number VA250W. I can turn the power on the laptop but the screen is black. I have already try taking the battery out and the power cord out and nothing.WHAT DO I DO?!?
SOURCE: laptop wont turn on orange light flashing on front
There could e a problem with the battery. A fast check to determine whether you have a problem with the power
adapter, power cord or the laptop's battery is to turn off the laptop,
remove the battery, connect the power adapter, turn on the laptop &
see if it works.
If the laptop works directly from the power adapter
with the battery removed, then the power adapter is good. In this case
we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
