After moving TV, the picture is squashed down leaving the top of the screen empty. The TV was fine before moving.
Either a broken connection from the move or bad solder connections on the vertical output chip, some sets if bad connection will try to open full when rapped on the top or side of the set (not with a mallet or way too hard please)
If not a connection it may be a bad part in the circuit---bad or broken connections are more common.
SOURCE: Picture is squeezed down to middle with a bright green horizontal
If you can do it, then just reheat or resolder the vertical ic pin for first step. If this work then no need to change the IC. Good soldering technique is needed. Do this when unit is no power and unplugged from wall socket.
Remember nasty voltages inside, it might caught you.
SOURCE: Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
