Question about Hobart HL600 Legacy Stand Mixer
Error code 11 for a hobart hl600 mixer
The mixer stops working after a short time and error code 11 comes up, the raise and lower function for the bowel still works but the mixer itself no longer functions, you have to turn the power of and on to clear it, nor are there any error codes in the manual i down loaded
1 Related Answer
bigg t
anthony james
  • 640 Answers
SOURCE: hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Posted on Nov 15, 2007
Where on mixer is screw #36
Move the lock lever, lift the head up. Look directly from the front into the area where it hinges and you will see a single slotted screw, anti clockwise to raise the beater up. There is a huge difference between a bowl and your bowel.
Oct 19, 2014 | KitchenAid Food Mixers
Why bowel not lifting after i put together
This is a kitchen device (mixer). I suggest you stop trying to use it as a medical device.
Jun 01, 2014 | Hobart M802 80 qt. 3 HP Dough Mixer
Oil dripping into bowel model km201
it just needs a new seal ..I had the same problem..it seems the seal will perish over time ...mine is back from repair and working perfectly
Nov 07, 2012 | Kenwood KM300 Chef Stand Mixer
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 18, 2009 | Food Mixers
Bowl too low
Hi, JAKELEGJEETE, You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 11, 2009 | Food Mixers
I have a kitchenaid stand mixer & the top is wobbly & hangs lower than it should & the plastic coating on the beater is starting to come off. How can I fix this?
Hi TH1754, you don?t mention your KA mixer model, but you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (for this example, I?ve used a KSM90P mixer) and select the last file listed that appears under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB) and save that file to your PC. You?ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below: Beater to Bowl Clearance Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance Tilt-Head models ? Unplug mixer. ? Lift motor head. ? Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater. ? Make adjustment with flat beater, so it just clears surface of bowl. If you over adjust the screw, the bowl lock lever may not lock into place. I hope this helps! ?Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid Food Mixers
The bowl fits too close to the mixing blade and has scraped some of the surface from the blade. I can not find the book
VLCMM: You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of yourOwners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC. You’llneed to have Adobe Reader to be able to open it. Turn to Page 11 and you will find theinstructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Make adjustment with flat beater, so it just clears surface ofbowl.
If you over adjust the screw, the bowl lock lever may not lockinto place.
Bowl-Lift models
• Unplug mixer.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flatbeater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface ofbowl.
If this solution has helped you, please rate it, thanks!. hslincoln
Nov 25, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer revs, then shuts off, will not reset
your kitchen aid has a little device inside called the hall effect sensor. These often come dislodged or just stop functioning. If you are mechanically inclined you can replace this yourself.
Oct 01, 2009 | KitchenAid KV25G0X Stand Mixer
Attachments do not reach the bottom of bowl when mixing
http://www.kitchenaid.com/custserv/faq.jsp?sectionId=222#troubleshooting
This is the FAQ from the Kitchen Aid website. It explains very well how to make the necessary adjustments under the question: My flat beater, wire whip and dough hook are scraping against the bottom of the bowl when I use my mixer. How can I fix this?
Dec 21, 2008 | KitchenAid K45SS Classic Stand Mixer
Plastic piece that raises and lowers the bowl
planetary is the mixining action which was started by kenwood on there mixers in the 50s
Dec 14, 2008 | KitchenAid KP2671 Professional 6 Series...
Hobart HL600 Legacy Stand Mixer Logo
352 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
