Question about Casio Sea Pathfinder SPF70-2V Wrist Watch
Where can Ipurchase a wristband for my Casio pathfinder watch?
Strap in torn
5 Related Answers
Misty Hoffman
  • 374 Answers
SOURCE: REPLACEMENT STRAPS
Call Casio Parts dept and they should be able to send you a band. 800-223-2001 is their number. :)
Posted on Jul 23, 2007
Anonymous
  • 73 Answers
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Posted on Jan 07, 2008
Anonymous
  • 111 Answers
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Posted on Sep 02, 2008
Techjoel
Joel
  • 79 Answers
SOURCE: New watch strap
I got mine from ebay. Its tough to install but I used a pen knife and a very small sdrewdriver. you can do it.
Good luck,
Techjoel
Posted on May 11, 2009
Techjoel
Joel
  • 79 Answers
SOURCE: Am looking for a users guide for module 3070 casio pathfinder watch.
Here's thre link to youtr manual.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3070.pdf
Good luck
Techjoel
Posted on May 16, 2009
Do you have a wrist band for SPF-70 Casio Sea Pathfinder
NO-- we do sell anything
if you need a wristband see your local jeweler
Where can I buy a replacement wristband for my casio twin resist TRT101H-1AV. Please i need someone to help me, i've searched everywhere for it, it was a present from'my mom,the band tore
Try support at the Casio website...eg for spares
http://www.casio.com/support/buyparts
(two outlets, one in CA one in NJ, emailis prob best depending on your location within US. If not in US you will need to try Ca eg sio website for that particular country.)
You could try downloading a manual to see what that says if you haven't already got one This webpage
Timepieces Watches Manuals CASIO
shows you how to do it (you need to get the 4 digit code from the back of your watch and type it into the box).
Some watches are made with the strap as an integral part of the watch and so in the proper sense cannot be replaced with a spare, the manual might tell you about this.
Failing all else you might try ebay or other such site where I have found casio watch straps for sale.eg (but not for your particular watch)
Genuine Factory Casio 25 16mm Black Twin Resin Replacement Watch Band...
18.April.2015
2helpful
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    1helpful
    2answers
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Need to replace the band.how can i get it
    spacer.gifYou may be able to get a replacement strap direct from Casio. If you go to "casio.com/" and click on "support", you will find a menu on the left.
    Click on repair and service and you will have two optional places to buy parts. There is no parts list but you can speak to them about your needs.
    If you want them to fit a strap for you, then the service center is the place to contact.
    Battery replacement prg 40 model 2271
    The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
    REPLACEMENT STRAPS FOR Casio Sea-Pathfinder SPF40-1V Wrist
    Casio Sea Pathfinder SPF70-2V Wrist Watch Logo
    Top Casio Watches Experts
    Ekse
    k24674
    Resolution IT Dubai
    Resolution IT Dubai
    Are you a Casio Watch Expert? Answer questions, earn points and help others
