Temperature gauge stays under c as i am driving but when i stop it goes up half way until i go again. just replaced thermastat.. Stiil doing it.. takes forever to get heat in car...I do get heat but it take forever to warn car up...
SOURCE: temperature gauge not working,stay cold
Hi. the vdc at the sensor seems to be fine. if the ground is sufficient, i would replace the gauge. its malfunctioning. Check for loose connection at gauge before replacing the gauge.
SOURCE: 200 Ford Focus 1.6, temperature gauge at full, even on ignition
is it your impeller, got a ford st24 and had the same problem,could only drive a short way before it got too hot again but the felt cold.
SOURCE: Erratic Dash Temperature Gauge Readings
assuming there is nothing wrong with the water pump, it may be the sending unit is going bad, or it could also be the thermostat going out. it is more likely that the t-stat is the problem as it is the erratic behaviour of the guage inside that is the concern.
SOURCE: Instrument cluster not showing odometer and
It could be the voltage regulator for your instrument cluster is the problem.
SOURCE: temperature gauge goes up all of the sudden
It sounds like you have air in the Cooling system and the bars leak permanent seal does not help. The sealer creates restrictions through out the water jackets and can cause the thermostat to stick. Replace the radiator cap and run the truck with the radiator cap on the first click and keep an eye on the over flow tank, refill the over flow as needed and make sure you have the heater on the highest setting to work out all the air in the system. Once all the air has worked it's way out of the system, then you can close the radiator cap to the second click to ensure full pressure is built up in your cooling system. Good luck and keep me posted.
Testimonial: "I'll try that! Thanks!"
http://schematicsdiagram.blogspot.com/2011/12/fuel-gauge-jumps-from-empty-to-full.html
Oldsmobile Temperature Gauge Lamp Switch?
http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
http://schematicsdiagram.blogspot.com/2011/12/temperature-gauge-went-up.html
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
http://technoanswers.blogspot.in/2012/02/how-to-remove-instrument-panel-on.html
If
all voltages checked ok, then most probably its faulty instrument cluster board
on which gauges are connected. Yes if cluster circuit board looks ok, then also
it can be faulty. Somewhere there is minute short or burn on board then such
problem arises.
Also
check the fuse box. One under hood and other under dash.
Inspect
each and every fuse and see if all are fine or not.
For
more troubleshooting on these cluster gauges I suggest you to refer the list of
help links mentioned below. Its step by step instructions will help you to
confirm the exact cause of problem in these conditions: ---------
Click
the link below: ------
2004 Toyota Tundra:
Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
2005 Lexus SC430: Fuel Door, Dome light and Fuel Gauge Fuse
Location?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-fuel-door-will-not.html
Toyota 4Runner:
Temperature Gauge Sensor
http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark?
http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge does not move and no heat when heater is
ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
2003 Pontiac
Grand Prix: Erratic Fuel Gauge?
http://technoanswers.blogspot.in/2012/06/2003-pontiac-grand-prix-erratic-fuel.html
Temperature gauge keeps fluctuating up and down close to
red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Temperature gauge on the dash quit working on Pontiac Grand
Prix?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Fuel gauge jumps from empty to full?
Gas gauge stuck on empty on 2002 Mercedes Benz 240c?
http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
• Oldsmobile
Fuel gauge drops to Empty?
http://technoanswers.blogspot.com/2012/01/fuel-gauge-drops-to-empty.html
Dodge neon gauges not working?
Temperature gauge went up?
Temperature gauge stays At cold on jaguar?
http://technoanswers.blogspot.in/2012/02/temperature-gauge-stays-at-cold-on.html
How to replace Instrument panel and dashboard on Toyota
car?
How to remove instrument panel on Chevrolet car?
How to remove control panel on Buick regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-control-panel-on-buick.html
These
details will help.
Thanks.
Toyota 4Runner: Temperature Gauge Sensor
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON?
Temperature gauge keeps fluctuating up and down close to red?
Prix?
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on
passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats,
Antifreeze out of reservoir and heater Blows Cold Air?
http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
These details will help.
Thanks.
replaced water pump also
Thank You
