Can the whirlpool cabrio dryer get hot enough to kill bedbugs?
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
SOURCE: Whirlpool Cabrio Dryer 3 months old
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
