Question about Insignia 32" 720p Flat-Panel LCD HDTV
Insignia ns lcd 32 wont power on - Insignia 32" 720p Flat-Panel LCD HDTV
Posted by dsallee106 on
Back2life Electronics
  • 933 Answers
When you plug in the set, does the standby light come on? Most likely you are dealing with either a failed power supply or main board. I would start with checked the power supply for bulged capacitors.
Posted on Dec 16, 2012
5 Related Answers
Anonymous
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
Anonymous
  • 9 Answers
SOURCE: INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
did you try calling the (877) 467-4289 Insignia help line?  I think they're open 24/7.  They just solved another Insignia problem for me.
Posted on May 14, 2008
Anonymous
  • 405 Answers
SOURCE: i have the following tv, Insignia
Power supply board most likely, I have one just like it with the same problem in my shop right now.
Posted on Dec 26, 2008
electrotech1
Veril Gillette
  • 1126 Answers
SOURCE: i have an insignia 32 LCD TV, it wont power up but
It is a bad power supply and that is common on that set, if you remove the back of the set and check the power supply board, you will find a couple of electrolytic caps that need change, or just replace the power supply.
Posted on Nov 14, 2010
Testimonial: "thats for your feedback. i appreciate it"
freelance-au
Darren Law
  • 131 Answers
SOURCE: insignia 32 HELLP
PHIHONG - PSM210-417A-R
Rather than spend hours and time on the kit, these guys have the board in.
Posted on Nov 18, 2010
HOW OLD IS MY INSIGNIA TV
correction your model must be : NS-32L430A11
its from 2007 or 2008
here full specs for your set
http://www.insigniaproducts.com/products/televisions/NS-32L430A11.html
thnaks
http://www.bostonrecycling.net/
Oct 08, 2014 | Insignia 32" 720p Flat-Panel LCD HDTV
Ns 32 lcd on/off continuously no picture speakers click when it turns on
Power supply module will be the first palce to check, look for 5vdc, 12vdc, and 24vdc. Look for bad caps with bulging tops also.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Insignia+IS-LCDTV32+
Jan 06, 2010 | Insignia IS-LCDTV32 32 in. Television
Will not turn on
check for defective capacitors in the power supply
Jan 08, 2009 | Insignia LCDTV26 26 in. Television
I have the following tv, Insignia 32" Flat-Panel LCD HDTV** (NS-LCD32-09CA) I get audio sound but no video output
Dec 26, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia 32" 720p Flat-Panel LCD HDTV Logo
185 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
