ASUS DRW-1814BL Internal DVD Drive Logo
Posted on Jan 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My DVD writer reads but does not write.
I am using ASUS DRW-1814BL DVD writer. When I insert
blank DVD disk (+-RW or +-R), it records 0 total space and 0 free space but when I insert a CD disk, blank or partly filled, it records its data correctly. It reads both DVD and CD correctly. What can be the problem how do I overcome it?
  • a_shadbolt Jan 20, 2009
    Hey, i have the same problem as well, i can read and write cds and read dvds, but when i try nero, roxio or even the windows writer they all give me errors when i try to burn dvds. Does anyone know why it does this?
Grubhead
Level 3:
  • ASUS Master 5,755 Answers
  • Posted on Jan 02, 2018
 Grubhead
ASUS Master
Level 3:
Answers
5755
Questions
Helped
1662382
Points
11417
DVD discs have to be formatted before they can be recorded on.
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Mar 24, 2007
SOURCE: Problems with my CD-RW\DVD-R
Maybe it's time to replace but try this last thing before opening the trash can lid:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers.
Anonymous
  • 382 Answers
  • Posted on Oct 28, 2007
SOURCE: ASUS DRW-1608p35
Odd considering video uses more bandwidth and cache than photos....how much ram is in your computer, and where are th ephotos youre attempting to copy?
Anonymous
  • 175 Answers
  • Posted on Jan 07, 2008
SOURCE: My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Anonymous
  • 17 Answers
  • Posted on Jan 23, 2008
SOURCE: ASUS DVD RW model DRW-1814BL
try reinstalling your operating system ( try format your cd or just repair it). The system will automatically detect the driver for your drive but if it was not listed in the bios try checking the cables attached to your drive.. or still if not.. the drive may be damaged.
RICHARDM69
Desktopsbyduck-Computers
  • 1061 Answers
  • Posted on Dec 14, 2008
SOURCE: ASUS P4P800 SE DVD WRITER NOT WORK
Turn the burn rate down.If that does not solve the problem.reinstall the burn program.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
1helpful
Using Windows XP. Want to copy vidoe from Media
Is the drive you are using a DVD writer or only a DVD reader? The drive that writes to RW disks is labeled DVD/RW or DVD Recordable.
These are the only drive types that will read and write a DVD/RW disc.
My DVD RW says some DVD-R's are CD-R's
make sure the disks are +- - + compatable to your burner
Explorer unable to read dvd+rw disc
Here, If u write into Blank cd\dvd using nero software, it will show the datails about ur disc status of remain sapce and used space.
And if u already write a files into on disc,
select ur combo drive, see thats properties.
0
Thanks & Regards
Manikandan.S
My Samsung CDRW/DVD SM352F plays commercial DVDs but will not recognise an inserted DVD/RW for recording picture files and shows properties as O bytes used space and O bytes free space. What is wrong?
the drive you are using is called a combo drive
CDRW- means CD WRITER
DVD- means DVD READER
DVD WRITER is not included in this combo...
only cd could be read and also written
but is case of DVD , it could only be read..
thankyou,.
regards
JC
2answers
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
The above internal burner not picking up blanck dvd-r
strictly speaking this is the correct response from your writer, as the disk "is" blank. Your DVD burning software, Like cloneDVD or Nero, should recognise the "blank" and then allow you to burn your disk image. you need to check that your DVD/CD authoring software is installed correctly and updated for all the latest features.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
