Question about GE Lands Phones
No dial tone on a cordless phone
After putting a new battery in the phone everything seems to work except there isn't any dial tone. I've checked the lines and the wall outlets both for power and phone both are o'k.
Posted by C P Sieg on
SD Tech
    Top Expert:
  • GE Master
  • 14,553 Answers
Some units if the battery is not fully charged or any ac adaptor for another phone also connected is not plugged in you will now have no dial tone.
Posted on Dec 15, 2012
5 Related Answers
Anonymous
SOURCE: GE 5.8 ghz cordless phone
My GE cordless phone , as well as my other phone , which are uniden cordless phone have lost their dial tones. I'm trying to reset my uniden phones by unplugging the bases and unplugging the batteries from the phones and wait for about 30 min. , then hook them back up and reset them to the bases again , they think that will work for the Uniden phones, but my GE phone doesn't have a reset program on the menu , do you have any other suggestions. Also I have a regular phone in my home and they are working properly , just my cordless phones are out.
Posted on Jan 27, 2008
Anonymous
SOURCE: Phone Not Working
I have had the same problem before and now again for the last week...I finally remembered what I did last time to solve it!
I put my "unavailable" Handset into the main cradle and left it there for a slow count of 20. That has reset the unavailable handset and returned the dial tone etc.
Maddening isnt' it!
Posted on Aug 03, 2008
Anonymous
  • 39 Answers
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Posted on Mar 20, 2009
Kyle
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
Anonymous
  • 9 Answers
SOURCE: continuous dial tone on phone line
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Posted on Oct 26, 2010
Not working
If you are getting a message on the screen, your battery is working. Try removing the SIM and give it a rub between your thumb and finger. Then refit it. sometimes the contacts become dirty and this can cause the fault you describe.
Jul 24, 2013 | Empire Comfort Systems Sanyo Clt-9812...
How do I reset my phone to reset to get back in range it says out of range anyone have instructions ?
Unfortunately, I do not have a manual for the GH-4102. However, most cordless phones get out of range messages at a few points: low handset battery, no power at the base or no dial tone at the base. Other possibilities are the phone base and handset lost the registration or one or the other isn't transmitting/receiving properly.
Things to try: unlpug the base power (from both the wall outlet and the phone) and phone line cord and remove the battery from each handset. Wait a few minutes and then reconnect the batteries and plug in the power and data connections. (Check when you unplug the base power adapter if it was warm; that indicates the unit was at least getting power at that point.) Recharge the handset batteries and then re-register the handsets, if needed.
Consider replacing the handset batteries if they are more than a year old (this includes the time that the phone may have been on a shelf after manufacturing). Try a new phone data cable (RJ11).
Next test your phone line and make sure that you have a dial tone. I like to use an old corded phone with the new phone cord for testing. If there is no dial tone, test the line at another jack. If there is still no dial tone, find your incoming phone line and open the service box. If you have a relatively new service, you will be able to plug your test phone into the service box and test there. If you can't test the line or there is no dial tone at the service box, contact your telephone company. They will test and fix outside problems for free.
If the problem is inside, look at all accessible wiring and make sure that the lines aren't damaged. If only one jack is bad, open the faceplate and fix any loose wires. There are two types of connections. The first holds the conductors under screws and the wire must be stripped back and secured. The other uses a keystone jack. The conductor wires are not stripped but a special tool punches the wires into place. You can find the punch-down tool at many hardware/home improvement stores in the wiring section. See http://www.lanshack.com/wire_phone_jack.aspx for a picture of the correct wiring for the jack.
If your phone line has a dial tone and the above fixes didn't work, contact the company and get the phone repaired if it is under warranty (usually 1 year). If it is out of warranty, then decide if it is worth repairing or if you should replace the unit.
I hope this helps.
Jan 09, 2012 | Southwestern Bell GH-4102 Twin Cordless...
Mar 20, 2009 | Uniden TRU9466 Cordless Phone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
No dial tone
try pulling the batteries out for 24 hours and then putting them back in. It should reset all the software and it should sync back up.
Jul 25, 2008 | Uniden DCT646-2 Cordless Phone
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Lands Phones Logo
199 people viewed this question
Top GE Lands Phones Experts
Bruce Robin
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
