Question about Pioneer VSX-915 Receiver
Pioneer vsx 915 blue light flashing
Hi, we have a pioneer vsx-915 amp. The standby / on light flashes blue and the amp does not power up. I have tried the enter+advanced surround combo and that gives me a message that says 'Amp error'. I have also tried the combo Tone + Standby/On but that doesn't do anything. Any other suggestions?
    Top Expert:
  • Pioneer Master
  • 14,553 Answers
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
Posted on Dec 15, 2012
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: My pioneer vsx 815 amplifier has a flashing blue
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Posted on Mar 04, 2011
VSX 60. MCACC blue Light flashes and unit will not turn on
try pressing and holding 'advanced surround' and the power button. This should reset the protect circuit. If it turns off again right away, then there is a problem with the amp that needs to be repaired.
Mar 25, 2014 | Pioneer VSX-52TX Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioneer VSX D712 wont turn on. Red light is flashing. How do we reset it?
Hi, Try pushing the "Advanced Surround" and "Enter" buttons together for about 3 seconds.
Aug 14, 2010 | Pioneer VSX-D712 Receiver
Standby/ON keps blinking...Pioneer VSX-D812
JUST PRESS ADVANCED SURROUND & ENTER FOR LIKE 3 SECONDS.. THAT WILL RESET THE SYSTEM CHIP INSIDE.. :)
Jul 27, 2008 | Pioneer VSX-D812 Receiver
Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Jun 18, 2008 | Pioneer VSX-915 Receiver
Receiver won't turn on. All I got is the flashing light.
Try pushing these buttons at the same timwe for a few seconds:
Advanced Surround + Enter..
'Advaned Surround' will be found in the front panel and 'Return' near the multi-jog dial.
cheers
Mohammed
Mar 09, 2008 | Pioneer VSX-D712 Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
Receiver just blinks standby will not power on
I have been so bummed, days now I have tried to get my Pioneer receiver to power on from standby with no luck.  We now have our receiver back, the same solution worked for us. Be sure to push the buttons on the receiver unit not the remote.  Thank You! Thank You!
Jan 30, 2007 | Pioneer VSX-D812 Receiver
Pioneer VSX-915 Receiver Logo
1,151 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
